03-10-2009, 08:39 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | K800i red blink and K770 dead set repaired thru dbss Code: -- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 000000E004FCFFFF Warning : Detected platform is different from selected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354271-02-264254-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354271-02-264254-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354271-02-264254-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352384-02-589073-4 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354271-02-264254-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Warning : Possibly wrong pin connected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354271-02-264254-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354271-02-264254-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380DF6725E08340 Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K800 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354271-02-264254-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380DF6725E08340 Reading GDFS... Error : Failed. --- Loading GDFS file---------------------------------------------------------- Loading "D:\maxtorE\@Dark_AlfoX_Toys\DreamBox\GDFS\K800_gdfs\K800_gdfs.dmap"... Done. --- Write GDFS----------------------------------------------------------------- User selected phone K800 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354271-02-264254-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380DF6725E08340 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K800 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354271-02-264254-9 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 2380DF6725E08340 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352384-02-589073-4 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352384-02-589073-4 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352384-02-589073-4 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352384-02-589073-4 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Timeout detected Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone K770 using Test Point boot mode Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352384-02-589073-4 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 238080602510D18F Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K770 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352384-02-589073-4 OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Baseband Chip ID = 9900 Phone ID = 238080602510D18F Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. Last edited by GSM Dream; 03-10-2009 at 15:54. Reason: Please, use "code" tag for logs. |
Sony Ericsson K800i RED Blink Repair Done By Setool3 | Sahil2007 | SETool2 | 0 | 11-24-2008 19:12 |
k800i red blinking repaired with dbss v3.4 | alfox | DreamBox | 0 | 04-22-2008 09:05 |
K800i red blink repair? | et.com | KULANKENDI Server | 7 | 03-03-2008 16:37 |
how to repair se k800i no power-red blinking and not posibility to conect | lalasdj | Sony Ericsson | 22 | 11-23-2007 08:13 |
how to repair K800i red blink cid49? | et.com | KULANKENDI Server | 17 | 08-21-2007 04:27 |
