Problem witch siemens cf75 Hi. Using the last version of DBSS, in test point boot mode, when Y tryin to read info or any other operation at this phone(CF75), the phone stop in "Powering phone..." PS.: NOT SHOW ME "OK" AFTER "Powering phone..." Any body can help me? |
Hi alvaroc! Did you have problem with other phones? Such reasons are possible: 1. You forgot to connect one of cables (cable of battery, or phone's cable) :) 2. You muddle up box's slots (DATA and SERVICE) - phone cable should be connected to DATA slot. 3. Phone has hardware damage. 4. One of cables was damaged. |
WIch other phones, all is OK! And if I select auto boot mode; wich battery, the phone dont power, but using test point cable, the phone power but ont work.... |
So, I think Quote:
----------------------------------------- Best Regards, GsmDream Team http://www.dreambox.hk |
I thinks is a bug. Using testpoint boot, After of power phone the DBSS show me the picture of test point. In other models, first power on phone, before, show image wich test point! :confused: :confused: :confused: |
Can you send ALL log files from DBSS with your forum's name and problem description to us? (Program Files->DreamBox->bin ALL .log files) Thanks. |
hi! Have any new? :confused: |
When you use Auto boot mode for CF75, please use battery! Use power from box only in Testpoint mode. Quote:
