Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > DreamBox
Old 06-28-2008, 11:28   #1 (permalink)
Member: 599037
Thanks Meter: 103
red light blinking k320i plz hlp
hi team i hav a k320i in red blinking k320.. plz tell me the complete procedure to repair that fone...... plz hlp me...
Old 06-28-2008, 11:34   #2 (permalink)
Member: 599037
Thanks Meter: 103
i m new to the drm box so ialso hav the setool and got the folowing erro on the setool... plz hlp me that what shud id ohere is the flashing log for the fone
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:50
Speed:921600
OTP LOCKED:1 CID:50 PAF:1 IMEI:35332201033993 CERT:RED
LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695
Flash ID check:897E
Flash props sent ok
writing E:\setool\flashes\sony ericsson\k320i\R4EA031_1250682_GENERIC_MA.ssw.cry
CURRENT FLASH FILE CID:50
SSW uses complete hash, hash len is:6320
Will flash 316 blocks...
SSW loading returns:0
writing E:\setool\flashes\sony ericsson\k320i\R4EA031_fs_Europe_1_MA_red_cid50.ss w.cry
SSW uses complete hash, hash len is:2340
Will flash 117 blocks...
LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009
loader startup: executed
Loader refused to start GDFS services,error is:5
loader GDFS startup failed, that is fatal
Elapsed: 410 secs.
and here is gdfs write procedure
SIGNED MODE (USING SERVER).
Will write GDFS now.
Open COM port OK
ChipID:8040,EMP protocol:0301
NEW SECURITY MODEL DETECTED
Speed:921600
Flash ID check:897E
Flash props sent ok
Elapsed: 14 secs.
Old 06-28-2008, 11:53   #3 (permalink)
Member: 599037
Thanks Meter: 103
here is drm box loggg
) Turn OFF the phone.
2) Connect the phone to DreamBox cable.
Boot Responce = 5A
Processor ID = 8040030101010101 (DB2012 R3A)
EROM Color = 4 : RED
EROM CID = 50
NOR Flash ID = 897E
OTP Status = LOCKED
OTP IMEI = 353322-01-033993-6
OTP CID = 50
EROM CID = 50
Error : Invalid GDFS and/or configuration.
Hint : Try to flash firmware.
Error : Failed.
Old 06-28-2008, 12:22   #4 (permalink)
kungpaoski's Avatar
Member: 329609
Thanks Meter: 245
Phone has damaged gdfs. try this Bro execute security bypass operations via tp. After you have completed stage 2. Go to security bypass tab. Write gdfs. Then unlock and repair gdfs blocks. For gdfs file try search here:http://www./showthread.php?t=514676.
b.r.
Old 06-28-2008, 12:46   #5 (permalink)
Member: 599037
Thanks Meter: 103
i wasnt able to find that gdfs file.. plz share here with me the gdfs file for k320i thanx
Old 06-28-2008, 13:56   #6 (permalink)
PRIMACELL's Avatar
Member: 427685
Thanks Meter: 103
Boot Responce = 5A
EROM CID = 50
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 50
EROM CID = 50
Error : Failed.
it does not support by DB,no solution yet
Old 06-28-2008, 17:09   #7 (permalink)
harim_1981's Avatar
Member: 243961
Sonork: 100.1591654
Thanks Meter: 104
yes wait for some Updations from DB...
now no solution for this condition...
Old 06-28-2008, 19:30   #8 (permalink)
Chevka's Avatar
Member: 82106
Thanks Meter: 1,208
The ONLY ONE Solution is use SE-Tool !!!Change the Flash IC with the New One and do Empty Fill Procedure which you can not do with another tool....
@dreambox team
We are still hoping a wonderful solution without changing the flash ic from you sir.....
as you claimed, DreamBox S.E. The tool for REPAIRING GDFS for Sony Ericsson Phones.
Come on, wake up Team....
make our "Dream" come true with DreamBox !!!
Old 06-29-2008, 07:09   #9 (permalink)
Member: 599037
Thanks Meter: 103
brothers i hav setool too.. but iknow that db vl release the solution for this problem soon... plz tea make the solution as soon as possible....
Old 06-29-2008, 14:03   #10 (permalink)
Member: 194370
Thanks Meter: 168
Boot Responce = 5A
EROM CID = 50
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 50
EROM CID = 50
Error : Failed.
select model w200 and try again
Old 06-29-2008, 19:02   #11 (permalink)
Member: 599037
Thanks Meter: 103
on selecting w200 it gives following log
User selected phone W200 using Test Point boot mode
1) Turn OFF the phone.
Boot Responce = 5A
EROM CID = 50
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 50
EROM CID = 50
Warning : Connected phone is not W200
Please select correct phone model
Seems to be K320
Warning : Aborted by user.
--- Reading Info---------------------------------------------------------------
User selected phone W200 using Security Bypass boot mode
Boot Responce = 5A
EROM CID = 50
Timeout detected
Error : Please execute "Security Bypass" operation first
Error : Failed.
what shud id o now??
Old 06-29-2008, 19:41   #12 (permalink)
5mobile's Avatar
Member: 70278
Thanks Meter: 19
mate, l m have k320 cid 51 ,but all l saw inthe forum only got cid50,how to downgrade the cid ,any solution???? pls help
User selected phone K320 using Normal boot mode
Boot Responce = 5A
EROM CID = 51
NOR Flash ID = 897E
OTP Status = Open
OTP IMEI = 048575-55-048575-4
OTP CID = 32783
EROM CID = 51
Warning : Connected phone is not K320
Warning : Unrecognized phone model
GDFS Simlocks :
Lock 0 = OFF (00) [5/5] (Network)
Lock 1 = OFF (00) [5/5] (Network Subset)
Lock 2 = OFF (00) [5/5] (Service Provider)
Lock 3 = OFF (00) [5/5] (Corporate)
Lock 4 = OFF (00) [5/5] (SIM Card)
Lock 5 = OFF (00) [5/5] (Extended)
Operator code = 000-00
Done.
Old 06-29-2008, 19:55   #13 (permalink)
Member: 599037
Thanks Meter: 103
Boot Responce = 5A
EROM CID = 51
NOR Flash ID = 897E
OTP Status = Open
OTP CID = 32783
EROM CID = 51
GDFS Simlocks :
Done.
y u need to dot hat???? and it wud be more better if u made a new thread instead posting in live thread bro so ppl can know ur problem...
Old 06-30-2008, 08:58   #14 (permalink)
Member: 194370
Thanks Meter: 168
Boot Responce = 5A
EROM CID = 50
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 50
EROM CID = 50
Seems to be K320
Boot Responce = 5A
EROM CID = 50
Timeout detected
Error : Failed.
why you do aborted ?
please try again
Old 07-01-2008, 20:56   #15 (permalink)
Member: 599037
Thanks Meter: 103
bro customer asked for his fone and i returned to him....but i found no result for this procedure.... it says not the same fone..
k320i red light blink geovicky Sony Ericsson 6 01-18-2010 15:40
k320i red light blinking bijugreat Cruiser Suite 3 05-13-2009 19:02
i have k800 with red light blink plz help amanhalwara Sony Ericsson Hardware Repair 2 05-02-2009 14:27
z310i only red light blinking but not power on plz help asif_ae Cruiser Suite 4 12-08-2008 23:56
z310i only red light blinking but not power on .plz help asif_ae Sony Ericsson Hardware Repair 0 12-08-2008 08:53
Page generated in 0.22201 seconds with 9 queries
