06-28-2008, 11:34 | #2 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | i m new to the drm box so ialso hav the setool and got the folowing erro on the setool... plz hlp me that what shud id ohere is the flashing log for the fone PHONE IS RED RETAIL PRODUCT FLASH CID detected:50 Speed:921600 OTP LOCKED:1 CID:50 PAF:1 IMEI:35332201033993 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 Flash ID check:897E Flash props sent ok writing E:\setool\flashes\sony ericsson\k320i\R4EA031_1250682_GENERIC_MA.ssw.cry CURRENT FLASH FILE CID:50 SSW uses complete hash, hash len is:6320 Will flash 316 blocks... SSW loading returns:0 writing E:\setool\flashes\sony ericsson\k320i\R4EA031_fs_Europe_1_MA_red_cid50.ss w.cry CURRENT FLASH FILE CID:50 SSW uses complete hash, hash len is:2340 Will flash 117 blocks... SSW loading returns:0 LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed Loader refused to start GDFS services,error is:5 loader GDFS startup failed, that is fatal Elapsed: 410 secs. and here is gdfs write procedure SIGNED MODE (USING SERVER). Will write GDFS now. Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:50 Speed:921600 OTP LOCKED:1 CID:50 PAF:1 IMEI:35332201033993 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 Flash ID check:897E Flash props sent ok LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed Loader refused to start GDFS services,error is:5 loader GDFS startup failed, that is fatal Elapsed: 14 secs. |
06-28-2008, 11:53 | #3 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | here is drm box loggg ) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353322-01-033993-6 OTP CID = 50 EROM Color = 4 : RED EROM CID = 50 Error : Invalid GDFS and/or configuration. Hint : Try to flash firmware. Error : Failed. |
06-28-2008, 12:22 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Phone has damaged gdfs. try this Bro execute security bypass operations via tp. After you have completed stage 2. Go to security bypass tab. Write gdfs. Then unlock and repair gdfs blocks. For gdfs file try search here:http://www./showthread.php?t=514676. b.r. |
06-28-2008, 13:56 | #6 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: PANGANDARAN BEACH Age: 44
Member: 427685 Status: Offline Thanks Meter: 103 | Quote:
06-28-2008, 19:30 | #8 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | The ONLY ONE Solution is use SE-Tool !!!Change the Flash IC with the New One and do Empty Fill Procedure which you can not do with another tool.... @dreambox team We are still hoping a wonderful solution without changing the flash ic from you sir..... as you claimed, DreamBox S.E. The tool for REPAIRING GDFS for Sony Ericsson Phones. Come on, wake up Team.... make our "Dream" come true with DreamBox !!! |
06-29-2008, 14:03 | #10 (permalink) | |
Freak Poster Join Date: Oct 2005 Location: iran
Member: 194370 Status: Offline Thanks Meter: 168 | Quote:
06-29-2008, 19:02 | #11 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | on selecting w200 it gives following log User selected phone W200 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353322-01-033993-6 OTP CID = 50 EROM Color = 4 : RED EROM CID = 50 Warning : Connected phone is not W200 Please select correct phone model Seems to be K320 Warning : Aborted by user. --- Reading Info--------------------------------------------------------------- User selected phone W200 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 50 Timeout detected Error : Please execute "Security Bypass" operation first Error : Failed. what shud id o now?? |
06-29-2008, 19:41 | #12 (permalink) |
Freak Poster Join Date: Jun 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 52
Member: 70278 Status: Offline Thanks Meter: 19 | mate, l m have k320 cid 51 ,but all l saw inthe forum only got cid50,how to downgrade the cid ,any solution???? pls help -- Reading Info--------------------------------------------------------------- User selected phone K320 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 51 NOR Flash ID = 897E OTP Status = Open OTP IMEI = 048575-55-048575-4 OTP CID = 32783 EROM Color = 4 : RED EROM CID = 51 Warning : Connected phone is not K320 Please select correct phone model Warning : Unrecognized phone model GDFS Simlocks : Lock 0 = OFF (00) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 000-00 Done. |
06-29-2008, 19:55 | #13 (permalink) | |
Member: 599037 Status: Offline Thanks Meter: 103 | Quote:
06-30-2008, 08:58 | #14 (permalink) | |
please try again | |
k320i red light blink | geovicky | Sony Ericsson | 6 | 01-18-2010 15:40 |
k320i red light blinking | bijugreat | Cruiser Suite | 3 | 05-13-2009 19:02 |
i have k800 with red light blink plz help | amanhalwara | Sony Ericsson Hardware Repair | 2 | 05-02-2009 14:27 |
z310i only red light blinking but not power on plz help | asif_ae | Cruiser Suite | 4 | 12-08-2008 23:56 |
z310i only red light blinking but not power on .plz help | asif_ae | Sony Ericsson Hardware Repair | 0 | 12-08-2008 08:53 |
