S 66 Cingular problem unlocking I can t unlock with Dreambox Power on the phone .....ok Error failed:confused: |
Same problem to S68 :( --------------------- [06/07/2006 06:59:43] User selected phone S68 using Test Point boot mode [06/07/2006 06:59:43] Hint : Please use testpoint and press button if ready [06/07/2006 06:59:44] [06/07/2006 06:59:44] Power On the phone ... OK [06/07/2006 06:59:44] Error : Failed. |
To Unlocker AL We need more information about your problem. What boot method did you use? To dancd Maybe you did not get a needle on a point ;) Can you send ALL log files from DBSS with your forum's name and problem description to us? (Program Files->DreamBox->bin ALL .log files) |
- By using test point it gives me the message below.If I had not conneted the test point correctly, the DBSS would not answer when I press the buton of test point. [06/07/2006 06:58:23] User selected phone S68 using Test Point boot mode [06/07/2006 06:58:24] Warning : You should conect power to your phone [06/07/2006 06:58:24] Hint : Please use testpoint and press button if ready [06/07/2006 06:58:25] [06/07/2006 06:58:25] Power On the phone ... OK [06/07/2006 06:58:25] Error : Failed. [06/07/2006 06:58:25] -In Firmware Bug mode the program works fine. After I access the menu and execute the SReader aplication, the phone makes his connection...I press OK...after all that I have waited 20 minutes and the phone can not be readed. 06/07/2006 06:43:21] User selected phone S68 using Firmware Bug (Manual) boot mode [06/07/2006 06:43:22] Warning : Please, connect the phone (Phone must be ON)!!! [06/07/2006 06:43:36] Warning : Please, start SReader application!!! [06/07/2006 06:43:36] Location : Games\SReader [06/07/2006 06:44:28] Working \ [06/07/2006 06:44:28] Warning : Aborted by user. [06/07/2006 06:44:28] [06/07/2006 06:44:31] --- Reading Info------------------------------------------ - In Auto boot mode DBSS can not execute SReader aplication...DBSS looks in Contacts etc. [06/07/2006 06:49:02] User selected phone S68 using Auto boot mode [06/07/2006 06:49:03] [06/07/2006 06:49:03] Power On the phone ... OK [06/07/2006 06:49:08] SIEMENS S68 [06/07/2006 06:49:08] Software version: 30 [06/07/2006 06:49:08] IMEI: 358439-00-143583-1 [06/07/2006 06:49:08] Warning : Please, do not forget to remove SIM card!!! [06/07/2006 06:54:43] Working | [06/07/2006 06:54:43] Warning : Aborted by user. [06/07/2006 06:54:43] [06/07/ 2006 06:54:51] --- Reading Info------------------------------------------ The phone is working fine...so the phone is not the problem...and DBSS works very good whit test point on other phones. I hope you will answer me soon... Best regards. |
yes i think is software problem ,I mean a bug becouse i unlock another phone s with testpoint never had a problem |
did you know this phone how many bands have i want to know if it works in 900 mhz |
