07-09-2006, 12:16 | #2 (permalink) |
Freak Poster Join Date: Sep 2002
Member: 15887 Status: Offline Thanks Meter: 16 | Same problem to S68 --------------------- [06/07/2006 06:59:43] User selected phone S68 using Test Point boot mode [06/07/2006 06:59:43] Hint : Please use testpoint and press button if ready [06/07/2006 06:59:44] [06/07/2006 06:59:44] Power On the phone ... OK [06/07/2006 06:59:44] Error : Failed. |
07-10-2006, 10:48 | #3 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | To Unlocker AL We need more information about your problem. What boot method did you use? To dancd Maybe you did not get a needle on a point Can you send ALL log files from DBSS with your forum's name and problem description to us? (Program Files->DreamBox->bin ALL .log files) |
07-10-2006, 12:16 | #4 (permalink) |
Member: 15887 Status: Offline Thanks Meter: 16 | - By using test point it gives me the message below.If I had not conneted the test point correctly, the DBSS would not answer when I press the buton of test point. [06/07/2006 06:58:23] User selected phone S68 using Test Point boot mode [06/07/2006 06:58:24] Warning : You should conect power to your phone [06/07/2006 06:58:24] Hint : Please use testpoint and press button if ready [06/07/2006 06:58:25] [06/07/2006 06:58:25] Power On the phone ... OK [06/07/2006 06:58:25] Error : Failed. [06/07/2006 06:58:25] -In Firmware Bug mode the program works fine. After I access the menu and execute the SReader aplication, the phone makes his connection...I press OK...after all that I have waited 20 minutes and the phone can not be readed. 06/07/2006 06:43:21] User selected phone S68 using Firmware Bug (Manual) boot mode [06/07/2006 06:43:22] Warning : Please, connect the phone (Phone must be ON)!!! [06/07/2006 06:43:36] Warning : Please, start SReader application!!! [06/07/2006 06:43:36] Location : Games\SReader [06/07/2006 06:44:28] Working \ [06/07/2006 06:44:28] Warning : Aborted by user. [06/07/2006 06:44:28] [06/07/2006 06:44:31] --- Reading Info------------------------------------------ - In Auto boot mode DBSS can not execute SReader aplication...DBSS looks in Contacts etc. [06/07/2006 06:49:02] User selected phone S68 using Auto boot mode [06/07/2006 06:49:03] [06/07/2006 06:49:03] Power On the phone ... OK [06/07/2006 06:49:08] SIEMENS S68 [06/07/2006 06:49:08] Software version: 30 [06/07/2006 06:49:08] IMEI: 358439-00-143583-1 [06/07/2006 06:49:08] Warning : Please, do not forget to remove SIM card!!! [06/07/2006 06:54:43] Working | [06/07/2006 06:54:43] Warning : Aborted by user. [06/07/2006 06:54:43] [06/07/ 2006 06:54:51] --- Reading Info------------------------------------------ The phone is working fine...so the phone is not the problem...and DBSS works very good whit test point on other phones. I hope you will answer me soon... Best regards. |
I need help me , problem unlock nokia e62 rm-88 cingular | DENISCASTILLO | BB5KING | 16 | 07-17-2009 16:51 |
Problem unlocking Moto Q9 from Cingular | tito millo | All UnlockByLogs Server | 6 | 01-27-2009 07:05 |
Cingular W810i Unlocking Problems | vermsky | Cruiser Suite | 3 | 11-01-2006 07:42 |
Cingular V551 Unlock problem | The Beast | Smart-Clip | 11 | 04-22-2006 18:24 |
