S500 stage 2 always failed can anyone lend a hand? i have a S500 on hand GDFS problem stage 1 works fine then stage 2 always failed i have 5060MOYOBE variant tested pin 11 & 12 always timeout failed here's the logs Code: Test Point boot mode regards swensonb DBSS user |
Bro have you read my thread about problem with new version?i stated there a simple trick to resolve tp 2 problem.now heres the trick.change your sensitivity on auto detect into 90% then try it again.pls post result ....im waiting |
ok i will try that bro thanks for the tip i will post results later regards swensonb |
just to update i tried playing with sensitivity change...but still....no luck always failed on stage 2... i just return it to customer.... regards swensonb |
I think that was hardware issue. |
