Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > DreamBox
Old 07-13-2008, 19:06   #1 (permalink)
Member: 137181
Thanks Meter: 3
S500 stage 2 always failed
can anyone lend a hand? i have a S500 on hand GDFS problem stage 1 works fine then stage 2 always failed i have 5060MOYOBE variant tested pin 11 & 12 always timeout failed
here's the logs
Test Point boot mode
[13/07/2008 01:39:13]  Stage 2 start
[13/07/2008 01:39:41]  Timeout detected
[13/07/2008 01:39:41]  Error : Failed.
also tried the EASY TP but still failed i have a microscope im sure im not connecting to ground always double checking
regards
swensonb
DBSS user
Old 07-14-2008, 00:00   #2 (permalink)
Member: 515413
Thanks Meter: 146
here's the logs
regards
swensonb
DBSS user
have you try refllash fw?,do repeat tp1 again,if problem still persist maybe damage flashchip.
Old 07-14-2008, 00:13   #3 (permalink)
alfox's Avatar
Member: 91411
Sonork: 100.1584444
Thanks Meter: 372
Bro have you read my thread about problem with new version?i stated there a simple trick to resolve tp 2 problem.now heres the trick.change your sensitivity on auto detect into 90% then try it again.pls post result ....im waiting
The Following User Says Thank You to alfox For This Useful Post:
Old 07-14-2008, 03:01   #4 (permalink)
Member: 137181
Thanks Meter: 3
ok i will try that bro thanks for the tip
i will post results later
regards
swensonb
Old 07-16-2008, 15:37   #5 (permalink)
Member: 137181
Thanks Meter: 3
just to update
i tried playing with sensitivity change...but still....no luck always failed on stage 2...
i just return it to customer....
regards
swensonb
Old 07-22-2008, 10:55   #6 (permalink)
GSM Dream's Avatar
Member: 214480
Thanks Meter: 2,087
I think that was hardware issue.
U600g Always fails at sme stage :( Indus NSPRO 10 04-19-2009 11:00
U600G Always fails at same stage :( Indus HWK 4 04-14-2009 13:02
DBSS 3.6 stage 2 always failed swensonb DreamBox 4 07-19-2008 14:54
Stage 2 always bad rzeszu DreamBox 3 02-27-2008 14:35
Page generated in 0.20566 seconds with 9 queries
