11-09-2008, 20:56 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 599037 Status: Offline Thanks Meter: 103 | siemens a52 problem.. plz hlp here here is the info log Reading Info--------------------------------------------------------------- User selected phone A52 using Boot Core BUG boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Error : Failed. --- Writing Flash-------------------------------------------------------------- User selected phone A52 using Normal (Cut track) boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Error : Failed. what shud i do? |
11-11-2008, 13:48 | #3 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Hello! Can you send all log (dbss.log, dbsserror.log) files from DBSS (Program Files -> DreamBox) to us (techaid[@]dreambox.hk)? Thank you. |
The Following User Says Thank You to GSM Dream For This Useful Post: |
11-11-2008, 20:07 | #4 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bangladesh
Member: 247758 Status: Offline Sonork: 100.1574842 Thanks Meter: 259 | Hello bro did you try to select with another model??(like a51 55 57) Please try to select with another model and post your result. |
The Following User Says Thank You to hackerbd For This Useful Post: |
11-11-2008, 21:53 | #5 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | yes i tried selecting a55 and got the following logs... -- Reading Info--------------------------------------------------------------- User selected phone A55 using Normal (Cut track) boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Phone ID = FD9E76EF Flash IMEI = 352838-00-050149-1 Manufacturer SIEMENS Model A55 Language lg1 Version 5 Warning : EELITE is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Done. -- Reading Info--------------------------------------------------------------- User selected phone A55 using Boot Core BUG boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Phone ID = FD9E76EF Flash IMEI = 352838-00-050149-1 Manufacturer SIEMENS Model A55 Language lg1 Version 5 Warning : EELITE is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Done. --- Reading Info--------------------------------------------------------------- User selected phone A55 using Stored Boot Key boot mode Power On the phone ... OK Sending loader ... OK Error : Failed. --- Reading Info--------------------------------------------------------------- User selected phone A55 using IMEI boot mode Power On the phone ... OK Warning : Your phone have cut track. Warning : Trying Normal (Cut track) mode. Power On the phone ... OK Sending loader ... Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Phone ID = FD9E76EF Flash IMEI = 352838-00-050149-1 Manufacturer SIEMENS Model A55 Language lg1 Version 5 Warning : EELITE is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Done. - Reading Info--------------------------------------------------------------- User selected phone A55 using Test Point boot mode Power On the phone ... OK Hint : Please connect the probe with a button to testpoint as shown in the description and wait. Hint : Now the probe might be disconnected Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Phone ID = FD9E76EF Flash IMEI = 352838-00-050149-1 Manufacturer SIEMENS Model A55 Language lg1 Version 5 Warning : EELITE is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Done. these r all the modes of read info.. now heres wen i try to repair security area using a55 - Repairing------------------------------------------------------------------ User selected phone A55 using Test Point boot mode Power On the phone ... OK Hint : Please connect the probe with a button to testpoint as shown in the description and wait. Hint : Now the probe might be disconnected Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Phone ID = FD9E76EF Flash IMEI = 352838-00-050149-1 Manufacturer SIEMENS Model A55 Language lg1 Version 5 Warning : EELITE is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Setting IMEI = 352838-00-050149-1 New SKey = 16585219 New Boot Key = 9D647987-0CDAACD1-77A531E5-0310BC1D New Boot Hash = AE012449-A54646FF-AABAF841-B4DAC4A8 Error : Failed. what shud i do?? |
11-12-2008, 06:07 | #7 (permalink) |
Member: 599037 Status: Offline Thanks Meter: 103 | chk here this log of flashing using a55.. -- Reading Info--------------------------------------------------------------- User selected phone V640 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 7A Processor ID = C8020401FFFFFFFF (A2) Warning : Aborted by user. --- Reading Info--------------------------------------------------------------- User selected phone V640 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 7A Processor ID = C8020401FFFFFFFF (A2) Warning : Aborted by user. --- Reading Info--------------------------------------------------------------- User selected phone A52 using Normal (Cut track) boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Error : Failed. --- Reading Info--------------------------------------------------------------- User selected phone A55 using Stored Boot Key boot mode Power On the phone ... OK Sending loader ... OK Warning : Aborted by user. --- Loading Flash File--------------------------------------------------------- Loading "F:\flashes\drmbox\siemens\a52\A52.fullflash.dtf". .. Language : lg91 Done. --- Writing Flash-------------------------------------------------------------- User selected phone A52 using Stored Boot Key boot mode Power On the phone ... OK Sending loader ... OK Warning : Aborted by user. --- Writing Flash-------------------------------------------------------------- User selected phone A55 using Test Point boot mode Power On the phone ... OK Hint : Please connect the probe with a button to testpoint as shown in the description and wait. Hint : Now the probe might be disconnected Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Phone ID = FD9E76EF Flash IMEI = 352838-00-050149-1 Manufacturer SIEMENS Model A55 Language lg1 Version 5 File name : F:\flashes\drmbox\siemens\a52\A52.fullflash.dtf Writting speed is 22641 cps Warning : Repair IMEI after FullFlash is not checked Done. --- Repairing------------------------------------------------------------------ User selected phone A55 using Test Point boot mode Power On the phone ... OK Hint : Please connect the probe with a button to testpoint as shown in the description and wait. Hint : Now the probe might be disconnected Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Phone ID = FD9E76EF Flash IMEI = 352838-00-050149-1 Manufacturer SIEMENS Model A52 Warning : Check phone model selection. Language lg1 Version 9 Warning : EELITE is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Setting IMEI = 352838-00-050149-1 New SKey = 99898718 New Boot Key = 320DA763-2647D630-ED06A4F6-300E20AA New Boot Hash = 8B96F6D6-84E72874-280F9603-353660AC Error : Failed. --- Reading Info--------------------------------------------------------------- User selected phone A55 using Normal (Cut track) boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Phone ID = FD9E76EF Flash IMEI = 352838-00-050149-1 Manufacturer SIEMENS Model A52 Warning : Check phone model selection. Language lg1 Version 9 Warning : EELITE is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Done. --- Repairing------------------------------------------------------------------ User selected phone A55 using Normal (Cut track) boot mode Power On the phone ... OK Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Intel 28F640J3, size 8192 Kb Phone ID = FD9E76EF Flash IMEI = 352838-00-050149-1 Manufacturer SIEMENS Model A52 Warning : Check phone model selection. Language lg1 Version 9 Warning : EELITE is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Setting IMEI = 352838-00-050149-1 New SKey = 73456201 New Boot Key = 50BEA62F-489B4441-BF132176-AD29BF28 New Boot Hash = EA90EB05-687A0D82-A51B295D-21D08318 Error : Failed. now what shud i do?? |
u600 keys very strange problem.. plz hlp me here.. | peter002 | HWK | 6 | 06-15-2009 15:39 |
need pinouts for lg u830.. plz hlp here | peter002 | FuriousGold | 8 | 03-22-2009 18:34 |
nokia 1112 ring problem ear pice problem plz hlp | WHED | Nokia Hardware & Hardware Repair | 1 | 11-07-2008 13:58 |
question for uid team very importent plz hlp here | priyanka | UID - Box | 6 | 09-09-2007 12:52 |
