07-27-2008, 13:24 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | stage 1 time!!! is this correct? till now 45 min and still proccessing!!!! |
07-27-2008, 14:11 | #3 (permalink) |
Member: 39208 Status: Offline Thanks Meter: 152 | --- Security Bypass------------------------------------------------------------ User selected phone K610 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351710-01-838117-7 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Warning : Aborted by user. about hour then i abort it!!!! |
07-28-2008, 07:35 | #7 (permalink) |
Member: 39208 Status: Offline Thanks Meter: 152 | actually there is something wrong..... i have k800 with damaged gdf, when i touch the tp, it takes also too long, about 1 hour and still proccessing!!!!!!, the tp for k800 is easy as everybody knows!!!! what's wrong? pls help? user selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-664185-5 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... ( about 1 hour and still ) Warning : Aborted by user. |
09-14-2008, 18:43 | #11 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Bangladesh
Member: 247758 Status: Offline Sonork: 100.1574842 Thanks Meter: 259 | Quote:
can't repair K790 after success in stage 1 and stage 2 | bifout | DreamBox | 3 | 08-14-2008 11:01 |
K510 2 stage fail *** time | Ciux | DreamBox | 10 | 05-05-2008 23:16 |
W200 cid52 fails at stage all time | msa | DreamBox | 2 | 04-23-2008 16:58 |
problem with Stage 1 or Stage 2 | west_bound | DreamBox | 1 | 03-20-2008 09:34 |
Upgrade griffin: Error stage 1 - 4602 | iknow | Griffin | 11 | 09-14-2004 23:42 |
