06-15-2006, 13:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Age: 44
Member: 252859 Status: Offline Thanks Meter: 53 | Suggesting Optional External Power supply for Dream Box I only used my box to unlock 2 phones. When I was ready to unlock a phone yesterday it started giving me errors. I don’t know if last update has anything to do with the problem. [14/06/2006 23:26:26] User selected phone A60 using Test Point boot mode [14/06/2006 23:26:26] Warning : You should conect power to your phone [14/06/2006 23:26:28] Warning : you have problems with battery connector, [14/06/2006 23:26:28] please check it. [14/06/2006 23:26:28] Warning : Battery voltage 2906 mV [15/06/2006 06:26:28] --- Reading Info--------------------------------------------------------------- [15/06/2006 06:26:28] User selected phone A60 using Test Point boot mode [15/06/2006 06:26:28] Warning : You should conect power to your phone [15/06/2006 06:26:29] Warning : you have problems with battery connector, [15/06/2006 06:26:29] please check it. [15/06/2006 06:26:29] Warning : Battery voltage 1771 mV [15/06/2006 06:26:30] [15/06/2006 06:28:55] Power On the phone ... [15/06/2006 06:28:55] Warning : Aborted by user. |
06-16-2006, 17:08 | #5 (permalink) | |
Member: 252859 Status: Offline Thanks Meter: 53 | Quote:
I will try a new cable and post the result. | |
06-16-2006, 17:29 | #6 (permalink) | |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Quote:
Who is your reseller? We change broken box free of charge (you pay only for sending). Contact with GSMServer team - you can send it to them. | |
06-16-2006, 19:30 | #7 (permalink) | |
06-19-2006, 05:48 | #9 (permalink) |
Crazy Poster Join Date: Aug 2004 Age: 41
Member: 76535 Status: Offline Thanks Meter: 1 | For your information the reason why your reseller maybe charging you repair or replacement cost is because you had broken their warranty seal sticker which was on the box, by opening up the box and checking the PCB. Many companies do have warranty terms. So before opening a box, always check with your reseller first, instead of opening the box and trying to fix the problem yourself. Please explain whole situation first before pointing any fingers. |
06-19-2006, 13:35 | #10 (permalink) | |
Please read my first post... I think i was clear to point out all needed details. | |
06-19-2006, 20:08 | #11 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 45
Member: 174505 Status: Offline Thanks Meter: 1 | From now on befor connect test point cable to your box , connect power cable to phone power pin and for disconnect situation... first disconect test point cable from box ..... 100% you haven't problem with your box. |
06-28-2006, 08:32 | #15 (permalink) | |
Freak Poster Join Date: Sep 2002
Member: 15887 Status: Offline Thanks Meter: 16 | Quote:
This solution is good! I had two boxes whit the same problem...and I have repaired them by changing that diode. The boxes now work verry good! I did'nt send them back to my reaseler . B.R. | |
Cruiser cable? Why not a external Power supply for the old connector? | Linkinsoldier | Cruiser Suite | 3 | 03-31-2006 18:13 |
Help about the external power supply for new SE phones. | franklee628 | Cruiser Suite | 9 | 08-18-2005 14:23 |
Power supply for Furious BOX type D | e-person | FuriouS II | 7 | 11-26-2004 03:47 |
Power supply for Griffin Box? | kimss | Griffin | 4 | 07-03-2004 20:04 |
I neeD urgently of cable shematics for external power supply 9v for cable for OTE 3X | doky | Alcatel & TCL Old Models | 0 | 02-15-2002 07:39 |
