11-21-2006, 16:47 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | DBSS v2.0, DreamBox Firmware 1.05 We are pleased to announce a release of new versions of DBSS v2.0 & DreamBox v1.05. In this update:
Best regards, GSMServer team DreamBox - Get more with it. * Format Bootcore access mode - direct boot for SGold-phones (without Java or Testpoint), but it delete original bootcore in the phone. P.S. Option "Delete custom data for EGOLD phones" did not pass a final test, so we did not include it to DBSS. We will add it soon. Instead of this we increased read Flash speed and changed a title . Last edited by GSM Dream; 12-03-2006 at 11:55. |
11-21-2006, 20:21 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Croatia Age: 49
Member: 234440 Status: Offline Thanks Meter: 20 | First big thanks to DreamBox team for this update, I wait this update because I have dead SL75 (dead after fullflash with DBSS with older version) and I waiting this new update and I repeat fullflash procedure with new version od DBSS. Down is complete log file what I make, but SL75 remain dead after all. I see that on bootloader is not any more fullflash for SL75. And I fullflash with this old file which was before on bootloader (SL75_100300[1].fullflash). What this mean that You did not put any fullflash file to bootloader? You want to stop any future fullflash of SL75 with dreambox? Please tell me, is there any solution for make alive again my SL75? Thanks Ivan --- Reading Info--------------------------------------------------------------- User selected phone SL75 using Test Point boot mode Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash Chip = Intel 28F256V18T, size 32768 Kb Flash Chip = Intel 28F256V18B, size 32768 Kb Flash IMEI = 357017-00-221****** Bootcore: SIEMENS SL75 Firmware: SIEMENS SL75 v13 lg1 Phone IMEI = 357017-00-22****** SPLock CRC = OK Phone Code = < NOT SET > : FF Done. --- Writing Flash-------------------------------------------------------------- User selected phone SL75 using Test Point boot mode Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash Chip = Intel 28F256V18T, size 32768 Kb Flash Chip = Intel 28F256V18B, size 32768 Kb Flash IMEI = 357017-00-221**** Bootcore: SIEMENS SL75 Firmware: SIEMENS SL75 v13 lg1 File name : C:\Documents and Settings\Ivan\My Documents\software\GSM\Flashevi\Siemens\S serije\SL75\SL75_100300[1].fullflash.dt f Writting speed is 69472 cps Done. --- Loading Flash File--------------------------------------------------------- User selected phone SL75 using Test Point boot mode Loading "C:\Documents and Settings\Ivan\My Documents\software\GSM\Flashevi\Siemens\S serije\SL75\v39\sl75_390400.update.firmwar e.dtf"... Done. --- Writing Flash-------------------------------------------------------------- User selected phone SL75 using Test Point boot mode Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash Chip = Intel 28F256V18T, size 32768 Kb Flash Chip = Intel 28F256V18B, size 32768 Kb Flash IMEI = 357017-00-221******* Bootcore: SIEMENS SL75 Firmware: SIEMENS SL75 v10 lg3 File name : C:\Documents and Settings\Ivan\My Documents\software\GSM\Flashevi\Siemens\S serije\SL75\v39\sl75_390400.update.firm ware.dtf Writting speed is 61572 cps Done. --- Running scenario----------------------------------------------------------- User selected phone SL75 using Test Point boot mode Repair IMEI (use factory defined from OTP area) Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash Chip = Intel 28F256V18T, size 32768 Kb Flash Chip = Intel 28F256V18B, size 32768 Kb Flash IMEI = 357017-00-221****** Bootcore: SIEMENS SL75 Firmware: SIEMENS SL75 v39 lg4 Phone IMEI = 357017-00-102******* Warning : Flash IMEI is not equal to Phone IMEI! Warning : Phone software could not work properly! Warning : Please, fix Phone IMEI! SPLock CRC = FAILED Warning : setting default lock data Setting IMEI = 357017-00-221***** Writting speed is 160 cps Done. --- Running scenario----------------------------------------------------------- User selected phone SL75 using Test Point boot mode Repair IMEI (use factory defined from OTP area) Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash Chip = Intel 28F256V18T, size 32768 Kb Flash Chip = Intel 28F256V18B, size 32768 Kb Flash IMEI = 357017-00-221551-8 Bootcore: SIEMENS SL75 Firmware: SIEMENS SL75 v39 lg4 Phone IMEI = 357017-00-2215**** SPLock CRC = OK Phone Code = < NOT SET > : FF Setting IMEI = 357017-00-2215***** Writting speed is 161 cps Done. --- Running scenario----------------------------------------------------------- User selected phone SL75 using Test Point boot mode Unlock all locks Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash Chip = Intel 28F256V18T, size 32768 Kb Flash Chip = Intel 28F256V18B, size 32768 Kb Flash IMEI = 357017-00-221551-8 Bootcore: SIEMENS SL75 Firmware: SIEMENS SL75 v39 lg4 Phone IMEI = 357017-00-2215***** SPLock CRC = OK Phone Code = < NOT SET > : FF Setting IMEI = 357017-00-22****** Writting speed is 161 cps Done. --- Reading Info--------------------------------------------------------------- User selected phone SL75 using Test Point boot mode Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash Chip = Intel 28F256V18T, size 32768 Kb Flash Chip = Intel 28F256V18B, size 32768 Kb Flash IMEI = 357017-00-2215****** Bootcore: SIEMENS SL75 Firmware: SIEMENS SL75 v39 lg4 Phone IMEI = 357017-00-2215****** SPLock CRC = OK Phone Code = < NOT SET > : FF Done. |
11-21-2006, 20:37 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 37
Member: 141164 Status: Offline Thanks Meter: 36 | its really nice update but i got disapointed that there is no support for E71 cuz most of siemens unlocking tolls got suport for this modle so why we those customer suffer who love dream box.despertly waiting for suport of E71. dream box team made my dream become true. |
11-22-2006, 11:28 | #7 (permalink) | |
Freak Poster Join Date: Aug 2002 Location: Belarus Age: 45
Member: 14420 Status: Offline Thanks Meter: 54 | Quote:
where is this menu option? i dont find - delete custom data in software... | |
11-22-2006, 12:57 | #9 (permalink) | |
Member: 241271 Status: Offline Thanks Meter: 30 | Quote:
Option "Delete custom data for EGOLD phones" did not pass a final test, so we did not include it to DBSS. We will add it soon. Instead of this we increased read Flash speed and changed a title . Last edited by DreamSupporter; 11-22-2006 at 13:09. | |
11-22-2006, 17:13 | #10 (permalink) |
Member: 14420 Status: Offline Thanks Meter: 54 | He-he... what's new? New interface? delete custom data - not released, xfs support - nit released... Sorry, but joker+x65PapuaUtils have biggest functionallity as DBSS at this day... |
11-22-2006, 18:20 | #11 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: The Arrivals
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks Meter: 173 | Quote:
thx gooood update | |
11-22-2006, 19:12 | #13 (permalink) |
Member: 14420 Status: Offline Thanks Meter: 54 | what about delete cust data for e-gold and xfs support? xfs flashing not support & DBSS not enter s-key to s-gold phones, and not possible update xfs with SWUP... |
DBSS v3.10, DreamBox firmware 1.15. A2 Unlock & Repair | GSM Dream | DreamBox | 51 | 12-05-2008 16:35 |
DBSS v3.10, DreamBox firmware 1.15 Discussion | FullFLASHgSMPH | DreamBox | 2 | 12-04-2008 15:24 |
DBSS v3.10, DreamBox firmware 1.15 | PhoneCareCenter | Service Products News & Updates | 0 | 12-02-2008 18:00 |
DBSS v2.4, DreamBox Firmware 1.08 | GSM Dream | DreamBox | 36 | 03-22-2007 04:11 |
DBSS v2.2, DreamBox Firmware 1.06 (FIRST IN THE WORLD: DIRECT support for S75 & SL75) | GSM Dream | DreamBox | 22 | 12-14-2006 16:47 |
