12-07-2006, 12:33 | #1 (permalink) |
Insane Poster Join Date: Aug 2005
Member: 170122 Status: Offline Thanks Meter: 14 | Update problem My Dreambox worked very fine until today when I tried to update to the last version of firmware and software. I used ver 1.29.2 / option Update firmware. It started to update the box but at about 60-70% I got an error. My Internet connection works fine, I use Windows XP. With ver 1.29.2 I get the next errors: If I try to connect to a phone (ex. A50) ---Reading Info ------ Error: can not connect to Dream Box (xxxx) Error: Failed. If I try to update: --Updating Box Firmware ----- Connecting to server...OK Trying to get firmware... Warning: Update not found. There are no new updates on server or your device is already up to date Done. If I select Reading Box Info ---Reading Box Info------ Box SN: xxxx Firmware Version: 1.04.0 Error: Failed. Please, remove your box from USB port. Than connect it, and try again. You nedd to upgrade firmware in your box if you see this message again. Error: Failed. If I try to update with version 2.2 I get the next errors: --- Updating Box Firmware-------------------------------------------- Connecting to server ...OK Warning : Update not found. There are no new updates on server or your device is already up to date Done. If I select Read Box Info: I get the next result: --- Reading Box Info----------------------------------------------------- Box SN : xxxx Firmware Version : 1.04.0 Error : Failed. Please, remove your box from USB port. Than connect it, and try again. You need to upgrade firmware in your box if you see this message again. Error : Failed. I reinstalled DreamBox (1.29.2 and then 2.2) I restarted my computer, I tried with a diffrent Internet connection. What should I do? Thanks in advance for your help. BR Florin |
12-07-2006, 16:00 | #3 (permalink) |
Member: 170122 Status: Offline Thanks Meter: 14 | Update worked! Hi, I tried to update again after your PM telling me to do that. The update worked with no problem! Now DreamBox is fully functional again! I used ver. 2.2 of software. Thanks again for your very quick support! BR Florin |
smti update problem | ashaka | SMTi | 1 | 03-29-2010 13:23 |
problem in s-card update problem | mahesh gandhi | Smart-Clip | 1 | 08-05-2008 08:10 |
Box update problem or problem with a reseller? | zeeber | Multi-Box | 24 | 01-18-2006 11:24 |
8850 updated problem. | jj008 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-18-2001 00:21 |
