07-17-2008, 13:31 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 44
Member: 52956 Status: Offline Thanks Meter: 49 | w200 always stop at stage2!!!!!!!!!!!!!!!!! my TP connection 100% correct here log: Code: -- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357354-01-873057-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Processing ... \ Hint : Now the probe might be disconnected Stage 1 completed succesfully Stage 2 start Timeout detected Error : Failed. |
07-19-2008, 16:14 | #3 (permalink) |
Member: 52956 Status: Offline Thanks Meter: 49 | I found reason for this error: I tested this phone with V3.5 result show this phone have "Invalid GDFS structure" and with version 3.6 pass the step 1 but in stage 2 alwyse show error ........ I think DREAMGSM TEAM may have remove bugs from v3.6 and repair stages for repairing "Invalid GDFS structure" see the log with v3.5 Code: -- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357354-01-873057-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... | Error : Invalid GDFS structure and/or configuration. Hint : Try to flash firmware. Error : Failed. GSMLOVER |
07-24-2008, 14:55 | #6 (permalink) |
Junior Member Join Date: Jan 2008
Member: 679992 Status: Offline Thanks Meter: 0 | Tp1 And Tp2 testpoint 1 on w200 works ok with 1.5v on needle, but TP 2 needs at least 3.0V (i used ext power supply) I used old siemens tp cable ,on tp 1 comes 1.5v but on stage of tp2 2.4 v ,so I need solution ,how to get 3.0 volts from box on stage 2 |
Canīt flash SL75. Always stops at 33% | chrisonic | DreamBox | 23 | 01-07-2007 05:06 |
w550 always stop at 38% ERROR: 30223B | mccm | SonyEricsson (USB-Smart) | 26 | 05-27-2006 02:24 |
K-300 FS flashing always stops at 38%!!! | MUNEEB_AKHTAR_RAZA | Cruiser Suite | 3 | 05-22-2006 18:36 |
try to flash dead v3,alway stop at 87%,please me | markLEE | Motorola P2k | 0 | 02-17-2006 13:48 |
MC60 - flashing always stops at 83% | realdodo | E-Gold Based Phones | 7 | 09-27-2004 20:02 |
