07-05-2008, 07:31 | #1 (permalink) |
Insane Poster Join Date: Mar 2005 Age: 45
Member: 126834 Status: Offline Thanks Meter: 0 | W200 CID53 problem after TP unlock with DB3.6 |
07-05-2008, 07:50 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Quote:
b.r. | |
07-05-2008, 17:31 | #5 (permalink) |
Freak Poster Join Date: Sep 2006 Location: forget
Member: 348988 Status: Offline Thanks Meter: 6 | just try unlock again just try unlock again Fast And Easy W200 Cid 53 DREAM TEAM, GODD WORK DONE I WAS ABLE TO UNLOCK W200 CID 53. KEEP THE GOOD WORK ON. BELO IS THE LOGFILE Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 53 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 353796-02- OTP CID = 51 EROM Color = 4 : RED EROM CID = 53 Processing ... | Hint : Now the probe might be disconnected Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 53 Baseband Chip ID = 8040 Phone ID = 2380046625F03069 Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone W200 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 53 Baseband Chip ID = 8040 Phone ID = 2380046625F03069 Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. Last edited by philip derby; 07-05-2008 at 17:41. |
07-05-2008, 18:11 | #6 (permalink) | |
Junior Member Join Date: Jun 2008
Member: 801229 Status: Offline Thanks Meter: 7 | well well well somebody is not here in the planet bro its not unlock prob as u can see he didnt flash the fs file its clear so he /you must flash again the unit with full flash (mcu fs cust) u see easy Quote:
07-05-2008, 22:58 | #7 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | Why dont u try to do again sec bypass operation (tp)then repair gdfs,then on the right upper side you can see a tab where you can optionally change your cid to 52 then after sec bypass and success tp youll see now that ur phone has changed its cid.then now u can flash it with flashfile available in support update:actually you dont need to do the tp anymore since you done it already.just attach the phone then choose cid52 on the tab located at the upper right part then press unlock repair gdfs.so after that your phone will be cid52 then flash it Last edited by alfox; 07-05-2008 at 23:05. |
The Following User Says Thank You to alfox For This Useful Post: |
Huawei T201 problem after success Unlock with FG | said4 | FuriousGold | 44 | 05-26-2008 17:45 |
V3I DEAD Again after tp unlock with SC | TRABEL | Smart-Clip | 8 | 05-11-2007 21:47 |
L7 Keypad Problem After Tp Unlock. Pls Help! | gsmawake | Motorola Hardware Repair | 2 | 11-16-2006 06:22 |
Please post here problems after TP unlock... | needi | Smart-Clip | 0 | 02-14-2006 17:45 |
powering on problems after bad unlock with GX-xx | iowtheme2 | Sharp | 0 | 06-09-2005 19:16 |
