07-05-2008, 06:51 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | W200 stage 2 problem broken tp line no.37 b.r. |
07-05-2008, 07:11 | #3 (permalink) | |
Member: 329609 Status: Offline Thanks Meter: 245 | Quote:
Nope i'm not trying to unlock unit. It was already unlocked via tp also but i accidentally broken the stage 2 tp line, trying to repair gdfs. Original problem of unit is this , when powered-up it just shows Ericsson logo and hangs there Cannot power off. I have flashed it several times using setool with different firmwares still the same. All flashing succesful. I have tried cleaning lcd connector contacts and keypad board connector still the same. So, I thought probably gdfs issue. b.r. | |
07-06-2008, 01:43 | #4 (permalink) |
Member: 329609 Status: Offline Thanks Meter: 245 | Manage to unlock repair gdfs. but still same problem hang in sony ericsson logo. Since unit was already unlocked via tp. No need to do tp anymore. Just select security bypass tab and do unlock repair gdfs. Thanks to sir dark alfox. But the problem still remains. Probably hardware issue. Will try to replace keypad board or lcd. Phone histroy was "wet unit". b.r. |
09-21-2009, 08:42 | #5 (permalink) |
Crazy Poster Join Date: Nov 2008 Location: sri lanka
Member: 902714 Status: Offline Thanks Meter: 5 | w200 stage 2 [test point] error,,,,,,,,,,,,,, with dreambox,,,,,,,,,,,, help/? 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color (BOOT) = 4 : RED EROM CID (BOOT) = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357355-01-605419-6 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Processing ... Hint : Now the probe might be disconnected Stage 1 completed succesfully Stage 2 start Timeout detected Error : #3140:003303FD Error : #3140:003406F6 Error : Failed. |
k810 gdfs stage 2 problem | khanmobiles0003 | SETool2 | 1 | 01-13-2010 20:48 |
W880 stage 2 problem | Allunlockingsource | DreamBox | 2 | 07-23-2008 10:50 |
