11-01-2008, 18:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | W580 Flash chip changed but.... look at the log below: -- Security Bypass------------------------------------------------------------ User selected phone W580 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = Open OTP IMEI = 048575-55-048575-4 OTP CID = <unknown> EROM Color = 4 : RED EROM CID = 53 Warning : Connected phone is not W580 Please select correct phone model Warning : Unrecognized phone model Warning : Empty board detected ... Warning : Connected phone is not W580 Please select correct phone model Warning : Unrecognized phone model Error : Failed. As already tried this solution on some other phones,i replaced flash chip with a new one(all process done carefully and IC well-placed).Now it boots but fails at the stage you see in the log. I connect in Testpoint mode but i get this error,checked for any shorting but all things seem ok.PLZ HELP. |
11-12-2008, 21:15 | #4 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | hi my friend please first use setoooool go to empty board select model select cid 49 put any number for imei select good gdfs(ex db2020gdfs_in_ssw_format_CID49_BROWN.ssw.cry) press flash stage 2 add erom (DB2020EROM_RED52_SIGNED_CID49_BROWN.ssw) press recovery flash with latest software if after flash no power on or red blink or white screen,please write good gdfs(C) and bypass with dream method by test point bye |
About DB2020 flash chip change | kwaku85 | Sony Ericsson Hardware Repair | 0 | 06-04-2008 21:20 |
DB Team please add W580 TP flash chip ball | GsmLiberty | DreamBox | 0 | 04-18-2008 19:03 |
v3r flash chip change | artur223 | Motorola Hardware Repair | 1 | 03-26-2007 16:01 |
V300 with cpu+flash chip change | Tom_x | Motorola P2k | 1 | 12-02-2005 19:07 |
6100 flash chip change | juht | Twisterflasher | 0 | 08-07-2004 11:24 |
