03-29-2008, 11:00 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: AnyClient Age: 44
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | W810 CID 50 5 lock closed - Repair successful !!! After repair/unlock, EROM upgrade to 52 also! |
03-29-2008, 11:27 | #4 (permalink) |
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | Here are logs Code: [29/03/2008 16:48:27] --- Security Bypass------------------------------------------------------------ [29/03/2008 16:48:29] User selected phone W200 using Test Point boot mode [29/03/2008 16:48:30] Stage 1 started [29/03/2008 16:48:30] 1) Turn OFF the phone. [29/03/2008 16:48:30] 2) Connect the phone to DreamBox cable. [29/03/2008 16:48:45] Boot Responce = 5A [29/03/2008 16:48:45] Processor ID = 8040030101010101 (DB2012 R3A) [29/03/2008 16:48:47] NOR Flash ID = 2019 [29/03/2008 16:48:47] OTP Status = LOCKED [29/03/2008 16:48:47] OTP IMEI = 356574-01-182352-7 [29/03/2008 16:48:47] OTP CID = 50 [29/03/2008 16:48:47] EROM Color = 4 : RED [29/03/2008 16:48:47] EROM CID = 50 [29/03/2008 16:48:47] Warning : Connected phone is not W200 [29/03/2008 16:48:47] Please select correct phone model [29/03/2008 16:48:47] Warning : Unrecognized phone model [29/03/2008 16:49:05] Hint : Now the probe might be disconnected [29/03/2008 16:49:14] Processing ... [29/03/2008 16:49:14] Stage 1 completed succesfully [29/03/2008 16:49:15] Stage 2 start [29/03/2008 16:49:34] Timeout detected [29/03/2008 16:49:34] Error : Failed. [29/03/2008 16:49:34] [29/03/2008 16:49:44] --- Security Bypass------------------------------------------------------------ [29/03/2008 16:49:44] User selected phone W200 using Test Point boot mode [29/03/2008 16:49:45] Stage 2 start [29/03/2008 16:50:10] Timeout detected [29/03/2008 16:50:10] Error : Failed. [29/03/2008 16:50:10] [29/03/2008 16:50:26] --- Security Bypass------------------------------------------------------------ [29/03/2008 16:50:26] User selected phone W200 using Test Point boot mode [29/03/2008 16:50:27] Stage 2 start [29/03/2008 16:50:41] Hint : Now the probe might be disconnected [29/03/2008 16:50:49] Processing... [29/03/2008 16:50:53] Entering Security Bypass mode ... [29/03/2008 16:50:53] 1) Turn OFF the phone. [29/03/2008 16:50:53] 2) Connect the phone to DreamBox cable. [29/03/2008 16:51:13] Boot Responce = 5A [29/03/2008 16:51:13] Processor ID = 8040030101010101 (DB2012 R3A) [29/03/2008 16:51:16] Baseband Chip ID = 8040 [29/03/2008 16:51:16] Phone ID = 2280DE701500852C [29/03/2008 16:51:16] Finalizing ... [29/03/2008 16:51:18] Stage 2 completed succesfully [29/03/2008 16:51:18] Done. [29/03/2008 16:51:18] [29/03/2008 16:51:28] --- Unlock and Repair---------------------------------------------------------- [29/03/2008 16:51:28] User selected phone W200 using Security Bypass boot mode [29/03/2008 16:51:28] 1) Turn OFF the phone. [29/03/2008 16:51:28] 2) Connect the phone to DreamBox cable. [29/03/2008 16:51:34] Boot Responce = 5A [29/03/2008 16:51:34] Processor ID = 8040030101010101 (DB2012 R3A) [29/03/2008 16:51:36] Baseband Chip ID = 8040 [29/03/2008 16:51:36] Phone ID = 2280DE701500852C [29/03/2008 16:51:36] Reading GDFS... [29/03/2008 16:51:38] Testing security ... [29/03/2008 16:51:38] GDFS 0013 Hash OK [29/03/2008 16:51:38] GDFS 0006 Hash Failed [29/03/2008 16:51:38] GDFS 000E Hash Failed [29/03/2008 16:51:38] GDFS 001C Hash OK [29/03/2008 16:51:38] Unlocking ... [29/03/2008 16:51:38] Testing security ... [29/03/2008 16:51:38] GDFS 0013 Hash OK [29/03/2008 16:51:38] GDFS 0006 Hash OK [29/03/2008 16:51:39] GDFS 000E Hash OK [29/03/2008 16:51:39] GDFS 001C Hash OK [29/03/2008 16:51:39] Generating GDFS... [29/03/2008 16:51:39] Writing GDFS... [29/03/2008 16:51:47] Done. [29/03/2008 16:51:47] [29/03/2008 16:52:03] --- Reading Info--------------------------------------------------------------- [29/03/2008 16:52:03] User selected phone W200 using Normal boot mode [29/03/2008 16:52:03] 1) Turn OFF the phone. [29/03/2008 16:52:03] 2) Connect the phone to DreamBox cable. [29/03/2008 16:52:06] Boot Responce = 5A [29/03/2008 16:52:06] Processor ID = 8040030101010101 (DB2012 R3A) [29/03/2008 16:52:08] NOR Flash ID = 2019 [29/03/2008 16:52:08] OTP Status = LOCKED [29/03/2008 16:52:08] OTP IMEI = 356574-01-182352-7 [29/03/2008 16:52:08] OTP CID = 50 [29/03/2008 16:52:08] EROM Color = 4 : RED [29/03/2008 16:52:08] EROM CID = 52 [29/03/2008 16:52:08] Warning : Connected phone is not W200 [29/03/2008 16:52:08] Please select correct phone model [29/03/2008 16:52:08] Warning : Unrecognized phone model [29/03/2008 16:52:09] GDFS Simlocks : [29/03/2008 16:52:09] Lock 0 = OFF (00) [5/5] (Network) [29/03/2008 16:52:09] Lock 1 = OFF (00) [5/5] (Network Subset) [29/03/2008 16:52:09] Lock 2 = OFF (00) [5/5] (Service Provider) [29/03/2008 16:52:09] Lock 3 = OFF (00) [5/5] (Corporate) [29/03/2008 16:52:09] Lock 4 = OFF (00) [5/5] (SIM Card) [29/03/2008 16:52:09] Lock 5 = OFF (00) [5/5] (Extended) [29/03/2008 16:52:09] Operator code = 000-00 |
03-29-2008, 13:04 | #5 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Phone will be CID52 I will suggest you 1 thing BRO Immediately make FULL BACKUP & upload it here ... If someone got W810 with CID52 with some software problem Your READED FULL FLASH will repair that PHONE Thanks |
03-29-2008, 14:43 | #6 (permalink) | |
Registered User Join Date: Oct 2003 Location: Vietnam Age: 47
Member: 40808 Status: Offline Thanks Meter: 10 | Quote:
B.R. P/S: also, let change language - if u need - before unlock! | |
03-29-2008, 19:11 | #8 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | Quote:
but its still in blinking its hardware isssue for sure so i will try to upload flash backup soon it may help people thanks | |
03-29-2008, 21:34 | #9 (permalink) |
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | YES First need working Phone Convert it to CID52 via TP then Read FULL FLASH with Security bypass .. then Write it to all Corrupted Phones |
03-30-2008, 17:32 | #10 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
can u plz post the TP pic here for the benfit of users..bcz w810 pcb is totally differ frm w200i........ | |
04-02-2008, 17:55 | #15 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Gsm-ALL Forum Age: 44
Member: 169337 Status: Offline Thanks Meter: 316 | Quote:
IT IS BOMB .REPAIR GDFS AND SECURITY UNIT FOR CID50/DB2012 REMMBER READ FULL FLASH AFTER THIS JOB BR TOPNET_GSM | |
w810 cid 50 5 lock | amin1999 | SETool2 | 3 | 10-14-2009 07:26 |
w810 cid 50 5 lock | amin1999 | Sony Ericsson | 3 | 10-13-2009 10:51 |
w810 cid 50 5 lock | amin1999 | Sony Ericsson | 0 | 10-13-2009 10:38 |
