07-25-2008, 21:10 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Devon, England
Member: 55766 Status: Offline Thanks Meter: 333 | w850 stops at 97% User selected phone W850 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) gets upto 97% then nothing happens this set was working ok and have previously been able to put it in bypass mode but now after full flash cant get it into bypass as it just shoots up but stops at 97 tried flashing in normal mode but still reading stops at 97% |
07-26-2008, 06:40 | #2 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 44
Member: 52956 Status: Offline Thanks Meter: 49 | Quote:
at this time dreambox have problem with recognize w850 cid 53 and you must select K800 in phone model tested and work if you want I can post log.. BR GSMLOVER | |
The Following User Says Thank You to GSMLover2010 For This Useful Post: |
07-26-2008, 10:26 | #4 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | I tried with stage 2 and just cant get it to accept TP always "working" time out and stage 1 just doesnt even start at all. @GSMLover2010 definitely not flashed with cid 53 but tried setting for k800 and still the same goes to 97% then just stops thats with k800 cid52. with k800 cid 53 setting doesnt even start process. |
07-26-2008, 14:47 | #5 (permalink) |
Member: 52956 Status: Offline Thanks Meter: 49 | my frind phone at this time is alive?whats problem? if phone die you can test this steps: 1-try with v3.5 with w850 & k800 2-I have many cases that problem in connect ic and usb Ic and with a heat or change problem was solved 3-if again always stop at 97% you can heat the flash ic or again not respon and still problem reball the ic then if still problem you must change flash ic.................... its all my experience br gsmlover |
07-26-2008, 15:51 | #6 (permalink) | |
Member: 55766 Status: Offline Thanks Meter: 333 | Quote:
07-27-2008, 20:13 | #9 (permalink) | |
so I supposed completely dead now | |
07-28-2008, 14:56 | #12 (permalink) |
Member: 55766 Status: Offline Thanks Meter: 333 | so I could have damaged phone while using Dreambox? Phone was ok before as I'd already identified phone with Setool before using DB and only after using DB it is now not seen. I did stage1 and stage2 ok earlier and completed it but later decided to do a full flash so tried to enter security again and this is when it got stuck at 97%, would allow stage2 but even though saying "working" always TP fail. If you reckon hardware is it possible to cause that by TP with DB then? |
08-04-2008, 12:36 | #15 (permalink) | |
use other box .............................................. problem in pre loader ...... we are waiting .......... update......... | |
reding phone stoped at 97% | HAMROUNI | SAGEM JTAG UNLOCKER | 6 | 11-10-2008 15:30 |
W850 Freeze At Sonyericson Then White | valentine aquil | SETool2 | 7 | 07-20-2008 17:40 |
V3i 0A.52 flashing stop at 97% | meneleo | Smart-Clip | 8 | 11-01-2007 11:32 |
Write RPL BB5 at N73 stop at Uploading NPC.... | bestncheap | Federal One | 1 | 09-11-2007 18:57 |
N95 UNLOCK PROBLEM-STOPPED AT 'stopped at testing challenge code 03" HELP | zonetrichur | Nokia Base Band 5 ( BB-5 ) | 2 | 09-08-2007 04:18 |
