10-09-2005, 14:59 | #1 (permalink) |
No Life Poster Join Date: May 2002 Location: distant galaxy Age: 50
Member: 12386 Status: Offline Thanks Meter: 18 | computer does not ask for any cable drivers i have just bought my usb-smart dongle but i am having problems running the cable. i have installed drivers for the usb dongle no problem. but when i put the 4in1 cable in to the usb port nothing happens does not ask for any drivers, i have also tried to plug it in to the phone still will not ask for drivers. can someone please help me i have tried it on 2 computers 98 and xp. put me i the right direction please thanks jab |
10-09-2005, 15:52 | #2 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: SWEDEN
Member: 45814 Status: Offline Thanks Meter: 34 | Quote:
Then it is ready to use.no need install again. Br Bernie | |
10-09-2005, 16:10 | #3 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Sweden Age: 39
Member: 177783 Status: Offline Thanks Meter: 0 | Just check in your Device manager in "PORTS (COM & LPT)". If you have anything that is named "UC-10" or similar to it your cable is correctly installed. |
10-09-2005, 17:52 | #4 (permalink) |
Member: 12386 Status: Offline Thanks Meter: 18 | hi all, thanks for the quick reply i have just checked in the ports/lpt no uc10. strange it finds the dongle i putt in but nothing when i put usb cable adapter. can the usb cable be faulty thanks jab |
10-09-2005, 17:58 | #5 (permalink) |
Member: 12386 Status: Offline Thanks Meter: 18 | hi there, just noticed can bluetooth serial make a difference in comports because it takes quite a lot of comports spaces. i will try to uninstall blutooth and nok pc suite then try. thanks jab |
10-09-2005, 18:13 | #6 (permalink) |
Member: 177783 Status: Offline Thanks Meter: 0 | Your bluetooth simulated serial-ports shouldn't be any problem. But if you look in the top of your device manager when your Cable is plugged in, do u have anything in "Other Devices" (this selection will only appear if you have any hardware that isn't installed correctly). If you still can't find the cable it's probably som fault in cable/PC, to be sure, try on another PC. |
10-09-2005, 19:23 | #7 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | mate, this is gliffy as hell this software basically, i can install the softwae on my laptop but cant install the cable drivers, but i can install the cable drives on my desktop, but not the software drivers its buggy mate |
10-10-2005, 19:10 | #8 (permalink) |
Member: 12386 Status: Offline Thanks Meter: 18 | hi all, thanks for the help i think its cable problem i have tried five diff. computers with no luick. when i get new cable i will let you know thanks jab |
Hope No One Ask For Se Emma Drivers After This Link | chiragp | Seking Server | 3 | 04-16-2008 13:57 |
Any solution for Zxxx cables driver?? ERROR_5 | Zein Zozza | UST Pro II | 3 | 08-15-2007 11:53 |
Ustpro 3.12 Does Not Run After Installing V804ss Driver | iruocoop | UST Pro II | 1 | 01-18-2007 04:19 |
XP does not want to accept the drivers for E616V using Crazzy v5 | MG77 | NEC | 1 | 08-11-2005 09:18 |
