Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 01-24-2006, 14:19   #1 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Arrow Dead K700 Problem when Flashing with USB-Smart
i have a dead K700 when i try to flash it it show following error message
and when i try to recover certificate i got following error
Any Help will be welcomed
Thnxxx in Advance
Take Care
ENJOY
Old 01-24-2006, 14:54   #2 (permalink)
struggler's Avatar
Member: 208691
try to charge batery full.
Old 01-24-2006, 15:44   #3 (permalink)
MadMax71's Avatar
Member: 194949
Don´t you need to select COM-Port?
Old 01-24-2006, 17:00   #4 (permalink)
Member: 16927
Thanks Meter: 134
No need select because he use UFSx/Twister interface.
Maybe try cable Fighter 4in1...
br,
fingusio
Old 01-24-2006, 19:09   #5 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Arrow
br,
fingusio
i dont have fighter cable so i try with T28 com cable and i got same error message there is something wrong with CID which got corrupted , i think i need to rebuild Certificate aread , but dont think so that USB-Smart can hanlde it.
Take Care
ENJOY
Old 01-24-2006, 22:17   #6 (permalink)
Member: 16927
Thanks Meter: 134
Hmmm how do you use T28 cable that you don't select COM port? Did you try on UFSx/Twister interface with using twister cable?
br,
fingusio
Old 01-25-2006, 06:35   #7 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Arrow
br,
fingusio
of course i did this i have separate box for UniBox cables and i unlock many SE using crack before buying USB-Smart and i very well understand the difference that which one is for Twister/UFSx and which one for UniBox. and when i select UFSx/Twister then i use its Cable and when i select T28 cable then i select proper COM port as well, and problem is still same every bettery is fully charged as well
Take Care
ENJOY
Old 01-25-2006, 06:51   #8 (permalink)
falak's Avatar
Member: 74749
Thanks Meter: 167
dear friend just use cruiser to get alive your phone again.usb smart cant help you now
thankx
falak
Old 01-25-2006, 06:58   #9 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
.Solution to any Software problems:
1. Flash EROM as MBN (MAIN) with Recovery checked and Complete NOT checked
2. Flash ...._MAIN + FS with Recovery NOT checked and Complete checked
3. Flash EEPROM Area as MAIN with both Recovery and Complete NOT checked
4. UNLOCK phone!
Thanks to Zulea for this easy explanation
Old 01-25-2006, 07:08   #10 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
4. UNLOCK phone!
first of all i dont can find EROM as MB on support and 2ndly i do job with just selecting Recovery but not work for me and other procedure will not be completed till first one got completed i means recovery of certificate, u can see both pictures i uploaded in 2nd picutre u can see that i just select RECOVERY OPTION not anyother option and once again there is no EROPM available on support as well
Take Care
ENJOY
Old 01-25-2006, 07:39   #11 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
I can send you eeprom from an phone, try flash as main with recover Certificate
Old 01-25-2006, 08:41   #12 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
Problem solved by reading the EEPROM from a working K700i and then do a repair of all the crcs etc, flash the 3 flash files and do a flash recovery.
Old 01-25-2006, 09:12   #13 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
if u have then kindly send me or post it on any free uploading server and put the link here
thnxxx in Advance
Take Care
ENJOY
Old 01-25-2006, 09:30   #14 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Arrow
i also try this reading eeprom from another K700i then try to write it with Recovery selected but problem is still same, here is the picture
Take Care
ENJOY
Old 01-25-2006, 09:48   #15 (permalink)
locer's Avatar
Member: 8435
Thanks Meter: 7
Need flash to W700i to flash with USB-SMART gsm_unlock2 Sony Ericsson 1 04-21-2007 15:21
sharp 902sh network problem after flash with USB smart doberman Sharp 2 12-02-2006 11:51
K750i dead during flash with USB-Smart sheikhje SonyEricsson (USB-Smart) 1 02-09-2006 08:47
J300i dead after flashing with usb smart som one can help??? .::Moby World::. SonyEricsson (USB-Smart) 8 12-20-2005 20:14
Page generated in 0.23369 seconds with 9 queries
