Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 08-17-2005, 14:25   #1 (permalink)
mobitek's Avatar
Member: 161012
Usb-Smart
Its assigned to virtual com4 but when i run semc and select com4 it cant open the port, any ideas pls
Old 08-17-2005, 20:55   #2 (permalink)
Member: 739
hi.
i have tested all this today, it seems that you have installed the drivers wrong just uninstall all usb port driver for the cable and after that install it again.
i got this problem to but after i uninstall and installed it again i got it to work.
After this go in software and select all this again and if it does this again just restart the soft and test again.
Br Gsmhq
Old 08-17-2005, 22:31   #3 (permalink)
Member: 136598
Thanks Meter: 3
make sure you check in device manager that is com4 cause mine went in com7
Old 08-18-2005, 01:18   #4 (permalink)
Member: 739
i have check around more and after i went int to safe mode on my xp system i checked on xp uninstall task and as my suprise i saw i hade 2 fighter and 2 cruiser cable drivers installed.
i uninstalled it went to standard xp system and installed again and now it's working without that message.
Hope this helps
Br Gsmhq
Old 06-03-2010, 13:44   #5 (permalink)
Registered User
Member: 275731
Thanks Meter: 6
usb smart driver need pls
Old 06-03-2010, 13:54   #6 (permalink)
AliAliGSM's Avatar
Member: 1052732
Sonork: 100.1616786
Thanks Meter: 3,145
Same as Setool & Cruiser
4in1_all_cable_drivers
Need Haier c5000 usb driver monto Various CDMA/TDMA Cell Phones 5 06-17-2013 08:28
USB ROM driver for UB jemmycell Universalbox 1 03-29-2010 14:13
3110c dead done by USB flashing Mintsea Universalbox 1 03-29-2010 11:54
Page generated in 0.16388 seconds with 9 queries
