K608i dead after READ ! Hi, i have a k608i, CID 49. Today i tried to READ firmware with 7.1 soft version. I have cruiser 4-1 cable working ok (i used it a lot of time, also for free k608 using Tp and setool) I made only read and have this log : Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2000_49_RED OTP CID: 49 Phone IMEI: 3568410XXXXXX Flash ID: 200D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Send FLASH application Read MAIN to file: "test.mbn" ERROR: 302414 Now phone simply doesn't start at all !!! Why and how is it possible to fix it without TP ? :eek: Thanks ! |
I just tried rebuild SP and have this log. Phone always DEAD at all ! :( Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2000_49_RED OTP CID: 49 Phone IMEI: 35684100XXXXX Flash ID: 200D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Send FLASH application Write GDFS Flashloader Switch phone ON Start GDFS Flashloader Rebuild SP area and CRCs Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Reading flash CXC version Version: R2M001_CXC1250077_EU_5_MI Send FLASH application Recover first flash part ERROR: CXC version not supported for recovery! |
yes...same trouble for me.... |
have you tray to connect it with TP ,,or just with cable ? ok for the CID49 ,,i think that you have solder the TP ,,so your problem is in the tp resistor ,,you must change it ,,or resolder it correctly ,,,and inch***** ,,all will work correctly good luck and best regards from SaLnAi :) |
And the problem is now that the phone is not working also for charge battery ! :( I have to take another k608 and charge battery in this way.... :confused: |
Only cable... So no hardware error for sure...i have not open phone at all ! :( |
yes..I recive 5 phone....2 work with testpoint....yesterday but today I try without testpoint..and one phone is now in PLEASE WAITING....and second is dead after READ function....and the last is without software intervention... |
Also flash it with k600 firmware and all ok ! Today try only READ with semc7.1 and kill one... :mad: May be i'll take again "old setool2" and with TP flash it with k600 firmware But i hope to have a solution without TP and have to open it ! :confused: |
please try and post the result here!!! |
I don't like too much to open k608i.... ;) |
guys I need flash files that is for K608 I know it is the same as K600 but my *******r wants his k608 back as he thinks it is better so I do have the full flash of repair for the K608 does that file include the file system 2 or what shall I do ?? thanx in advance |
Do you have usb-smart? if yes..go to support...all files is in support area... What is Cid for your phone....? This post is for dead phone after read with usb-smart... |
sorry Mr well :eek: 1. I am posting here coz I have a usb smart :mad: 2. In the support area there is no files for K608=k600+8 ;) 3. I know it for the dead bla bla bla :( 4. My dead phone is alive but after reflash and 2 K600 = k608-8 ;) 5. CID 49 ofcourse was the phone (and the flash files needed at any CID even CID 1) ;) b4 complaining check the support area and see for urself :o happy new year :D :cool: |
Also tried to flash recovery firmware... No good idea... :mad: Always the same... May be better to use old setool2 and TP for flashing good K600 firmware... Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2000_49_RED OTP CID: 49 Phone IMEI: 35684100XXXXX Flash ID: 200D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Send FLASH application Send MAIN flash file: "K600_CID49_R2F015_FullRepairFlash.mbn" ERROR: 30223B |
K... what is the diference beetwin one k600 and k608 ..both with original firmware? I don't know, because I haven't one k600... |
