semc TOOL V4.2 Needed, k750 dead Hi Hi have a K750 that came to me with white screen . I could flash it once but to not complete phone at the end and the phone now Completly dead. Certificate not find or error 304106 Looked arround for any solution, but only find I must try version 4.2 and this version is nowhere to be found. I tried all other suggestions Please I need this and also any available solution for this problem. [email protected] [email protected] BR Keke |
Hi, check your mail box :) |
you must download from support full flash repair for k750, flash the phone, after check COMPLETE PHONE box, press do jobs flash erom and unlock. this is all. good luck |
man make this step by step 1 recover certificate 2 flas erom as main 3 then full repair flash as main 4 then eeprom as main 5 then write gdfs 6 and last u make complete fone ryaz |
Hi All Thanks for all your replies But I have done all of that. The problem phone would not even start flashing,with , erom, eeprom or main. Isert erom as main recoveret certificate cheked certificate recovert powering phone Error 304106 Nothing else... Same with full flash or fs. I do not know what can be de the problem. I am having this result with setool Open COM port OK Elapsed:18 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS INVISIBLE (00000000) NO valid FLASH CID detected (00) Cowardly refusing to load empty loader. failed to load CERTLOADERS,try to use RECOVERY. Elapsed:0 secs. And this when I try recovery RECOVERY MODE STARTED Open COM port OK PHONE IS INVISIBLE (00000000) Recovery:041213 1452 MATCXC1326739_COMPACTCERTLOADER R2L Fetching phone data from OTP OTP status:0 locked:1 CID:36 PAF:1 IMEI:35655200989439 CERT:RED bad file, will not flash it. Recovery failed. Phone dead. Elapsed:7 secs. I will try to rehot the phone and try again. BR keke |
