04-07-2006, 16:45 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | semc TOOL V4.2 Needed, k750 dead Hi have a K750 that came to me with white screen . I could flash it once but to not complete phone at the end and the phone now Completly dead. Certificate not find or error 304106 Looked arround for any solution, but only find I must try version 4.2 and this version is nowhere to be found. I tried all other suggestions Please I need this and also any available solution for this problem. [email protected] [email protected] BR Keke |
04-07-2006, 16:59 | #3 (permalink) |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | you must download from support full flash repair for k750, flash the phone, after check COMPLETE PHONE box, press do jobs flash erom and unlock. this is all. good luck |
04-07-2006, 18:00 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: gsm market Age: 35
Member: 222481 Status: Offline Thanks Meter: 30 | man make this step by step 1 recover certificate 2 flas erom as main 3 then full repair flash as main 4 then eeprom as main 5 then write gdfs 6 and last u make complete fone ryaz |
04-08-2006, 14:54 | #5 (permalink) |
Member: 12733 Status: Offline Thanks Meter: 26 | Hi All Thanks for all your replies But I have done all of that. The problem phone would not even start flashing,with , erom, eeprom or main. Isert erom as main recoveret certificate cheked certificate recovert powering phone Error 304106 Nothing else... Same with full flash or fs. I do not know what can be de the problem. I am having this result with setool Open COM port OK Elapsed:18 secs. Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS INVISIBLE (00000000) NO valid FLASH CID detected (00) Cowardly refusing to load empty loader. failed to load CERTLOADERS,try to use RECOVERY. Elapsed:0 secs. And this when I try recovery RECOVERY MODE STARTED Open COM port OK PHONE IS INVISIBLE (00000000) Recovery:041213 1452 MATCXC1326739_COMPACTCERTLOADER R2L Fetching phone data from OTP OTP status:0 locked:1 CID:36 PAF:1 IMEI:35655200989439 CERT:RED bad file, will not flash it. Recovery failed. Phone dead. Elapsed:7 secs. I will try to rehot the phone and try again. BR keke Last edited by Keke; 04-08-2006 at 15:14. |
...::: SEMC Tool v4.0 - CHANGE IMEI on ALL new ARM SEMC :::... | zulea | SonyEricsson (USB-Smart) | 114 | 12-09-2005 14:15 |
SEMC Tool v4.2 - Z520i support added and something more | zulea | SonyEricsson (USB-Smart) | 42 | 11-17-2005 23:17 |
SEMC Tool v1.2 released | zulea | SonyEricsson (USB-Smart) | 0 | 08-30-2005 08:50 |
Semc Tool v2.2 Error | DMNokia | Sony Ericsson | 7 | 08-14-2005 18:37 |
