Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 03-03-2006, 22:11   #1 (permalink)
masterspargo's Avatar
Member: 227726
Thanks Meter: 297
w550 after unlock semc v6.5 dead
i wan full flash with semc 6.6 with test point but
Switch phone ON
Get phone info
Flash CID: 49
Phone KEY: A1_DB2010_49_RED
OTP CID: 49
Phone IMEI: 35744200540491
Flash ID: 890D
Switch phone ON
Send FLASH application
Send MAIN flash file: "W550_R4AB048_HONG_KONG.mbc"
and measeag
out of memory while expanding memory stream
i try this way
1. - Use Test Point - Checked
- Skip TP when flash MAIN, FS - NOT Checked
- Complete phone after flash - NOT Checked
- Recover Certificate - NOT Checked
- Flash W550_EROM_CID49_RED.mbn as MAIN file
- Connect/disconnect Test Point on phone when software ask
2. - Use Test Point - Checked
- Flash (your choice) MAIN file from MAIN_IMEI directory
3. - Use Test Point - Checked
- Skip TP when flash MAIN, FS - Checked
- Flash (your choice) FS file from FS directory
- Not need to use Test Point on phone
4. - Use Test Point - Checked
- Flash W550_EEPROM_Area_Flash.mbn as MAIN file
5. - Use Test Point - Checked
- Complete phone after flash - Checked
- Remove all filenames from MAIN and FS edit boxes
6. - Use Test Point - Checked
- On Repair tab mark Rebuild SP Area and Remake CRC's
- Do Selected Jobs
7. - Use Test Point - Checked
- On Unlock tab mark Clear SP Locks
- Do Selected Jobs
but the same massage
out of memory while expanding memory stream.
plz help me what i do
thanks in adv
w550 after unlock semc v6.5 dead masterspargo SonyEricsson (USB-Smart) 4 03-13-2006 09:53
w550 after unlock semc v6.5 dead masterspargo Sony Ericsson 0 03-03-2006 22:17
NEC e338 is halfdead after unlock with crassy 5 Irfangk786 NEC 3 05-30-2005 23:44
nec 338 hang after unlock with crassy 5.0 fancyvpp NEC 5 05-25-2005 00:45
C65 dead after unlocking with sst 5.31 rachelyna S-Gold Based Phones 9 05-05-2005 17:08
Page generated in 0.18615 seconds with 9 queries
