03-03-2006, 22:11 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 41
Member: 227726 Status: Offline Thanks Meter: 297 | w550 after unlock semc v6.5 dead Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35744200540491 Flash ID: 890D Switch phone ON Send FLASH application Send MAIN flash file: "W550_R4AB048_HONG_KONG.mbc" and measeag out of memory while expanding memory stream i try this way 1. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash W550_EROM_CID49_RED.mbn as MAIN file - Connect/disconnect Test Point on phone when software ask 2. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash (your choice) MAIN file from MAIN_IMEI directory - Connect/disconnect Test Point on phone when software ask 3. - Use Test Point - Checked - Skip TP when flash MAIN, FS - Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash (your choice) FS file from FS directory - Not need to use Test Point on phone 4. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash W550_EEPROM_Area_Flash.mbn as MAIN file - Connect/disconnect Test Point on phone when software ask 5. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - Checked - Recover Certificate - NOT Checked - Remove all filenames from MAIN and FS edit boxes - Connect/disconnect Test Point on phone when software ask 6. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Repair tab mark Rebuild SP Area and Remake CRC's - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask 7. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Unlock tab mark Clear SP Locks - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask but the same massage out of memory while expanding memory stream. plz help me what i do thanks in adv |
w550 after unlock semc v6.5 dead | masterspargo | SonyEricsson (USB-Smart) | 4 | 03-13-2006 09:53 |
w550 after unlock semc v6.5 dead | masterspargo | Sony Ericsson | 0 | 03-03-2006 22:17 |
NEC e338 is halfdead after unlock with crassy 5 | Irfangk786 | NEC | 3 | 05-30-2005 23:44 |
nec 338 hang after unlock with crassy 5.0 | fancyvpp | NEC | 5 | 05-25-2005 00:45 |
C65 dead after unlocking with sst 5.31 | rachelyna | S-Gold Based Phones | 9 | 05-05-2005 17:08 |
