903sh-2006 was dead after unlock i flash via TP my 903sh-2006 ok,but when i unlock via TP it appeared :Switch phone ON ... Send application ... ERROR 400113 or Switch phone ON ... Send application ... ERROR 400114 or Switch phone ON ... Send application ... ERROR 400110 or Switch phone ON ... Send application ... ERROR 400115 my phone is now no power on,when i flashed it again it also displayed: Switch phone ON ... Send application ... ERROR 400113 or Switch phone ON ... Send application ... ERROR 400115 Can anyone help me please????? |
hi guys i hAve dead 903sh cid73 after unlock. my phone not turn on. now i can't connect to soft. help me. please help me. what is my problem. i'm use full charged battery. thank you |
just like my problem.....i just disaassemble the phone safely and the phone wont power on right now...... |
Hi pls Check your TP Correct ;) Br c2r2gsm.com |
:( Quote:
i flashed via TP before,the phone `s power was on,but when i u unlocked via TP ,it always displayed Error 400114 and the power wasnt on,what is problem with my phone,please help me. Many thanks.:( |
Trying to full battery and connect to test point and reflash then phone is Ok. I'm have 5 phone to go die and trying more flash alot then Ok. Hope you enjoy to 2006 Sharp CID 73. Best & regards |
even you flash a dead flash into a phone, whenever you wanna unlock or connect the phone, it shoulbe be able to detect your phone the error you got means USBSmart cannot connect ... 99% that you make mistake, not the USBSmart's mistake ... 1. check if your tp is still soldered onto the board correctly 2. procedure ok? (connect tp then insert battery ... etc) my experience, on my first CID73 Sharp, I DID damaged the TP and got the same error as you ... after fixing the TP (i broke the resistor's connnection to the board), all went smoothly when connecting for flashing/unlocking .... and my 2nd CID73 sharp, i did TP very carefully, no problem at all ~ |
please tell me how to fix the TP,i think i did like you said,so my phone was broken. Best regard:( |
Switch phone ON ... Send application ... ERROR 400115 please tell me what can i do? many thanks:( |
sharp 903 / 703 cid73 dead after unlock, --check your cable and power supply --check the testpoint --correct flash file --last thing is the timing in flashing a while ago, we've flashed 903 and 703 cid 73 and flashing successfull br, MEGATRIO team |
1 Attachment(s) This is test point good. I'm have checking and tested. |
1 Attachment(s) Quote:
i flashed via v2 TP,and the phone`s power was on,but sim emp,then i unlocked with the same TP,it always display: Switch phone ON ... Send application ... ERROR 400115 or Switch phone ON ... Send application ... ERROR 400114 or Switch phone ON ... Send application ... ERROR 400113 and now the phone has no power on ,it was dead because the SW cant read,have you got any solution?please help me, maybe i will try the test point you shew. many thanks |
i tried to do another phone,it is ok and it is unlocked,but my phone still problem,i cant recharge battery by this phone(no power on the lamp)the USB-SMART also cant read the phone,when i flash it normal(NON TP) it always show: Switch phone ON ... Send application ... ERROR 400115 Switch phone ON ... Send application ... ERROR 400115 and when i unlock it normal(non TP) Switch phone ON ... Get phone info ERROR 400115 Switch phone ON ... Get phone info ERROR 400115 Switch phone ON ... Get phone info ERROR 400115 anybody please show me how can i save my phone. many thanks:( Mr Zulea please help me!!!!!!!!!!!!! |
hi guys please help me. how resolve my problem.......................................... i'm using full charged battery. soft can't detect my phone. zulea help me..................... need repair solution thank you |
my phone is same your,it cant detected by usb-smart,i am waiting for repairing solution too.:( :( :( :( :( B.R |
