04-08-2006, 08:46 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Earth
Member: 38573 Status: Offline Thanks Meter: 0 | V360 test point problem But today I tried to unlock another 3 of them, wouldn't work at all for some reason. When I connect the test point to the ground yesterday, my computer was detecting new device connect the PC(Winxp Pro), and then unlock succesfully. When I connect the test point to the ground today, nothing happens. Won't unlock at all just like you never ground the test point. Anyone has similiar experience? B.R flin898 |
04-09-2006, 15:05 | #3 (permalink) | |
Member: 38573 Status: Offline Thanks Meter: 0 | Quote:
04-09-2006, 15:05 | #4 (permalink) | |
04-09-2006, 20:04 | #6 (permalink) | |
Banned Join Date: Aug 2004 Location: Gsm Unlockers Awareness Report
Member: 76978 Status: Offline Thanks Meter: 15 | Quote:
Its a simple and easy tool to use works like a can opener. http://forum.gsmhosting.com/vbb/show...11&postcount=1 Last edited by ednacell; 04-10-2006 at 02:07. | |
04-11-2006, 13:19 | #7 (permalink) |
Member: 38573 Status: Offline Thanks Meter: 0 | Another question about test point. Like Zulea said the test point wasn't connecting properly as I tried 4 different fones, there's absolute no damage on the fone. Must be something wrong with the test point. I unlocked 2 v360 before, what I did was connect USB cable to the phone, connect the test point then WINXP will detect a device connected, run the P2K tool, unlock. But now when I connect the test point, computer is not detecting anything, run the program, says no connection. Turn the fone on, the bootloader is still the original one therefore test point didn't connect properly. Tried a few different tools to connect the test point to the metal shield, still no good. Will try using a wire tomorrow. Anyone has similar experience? Or i did something wrong with the test point? |
04-11-2006, 13:30 | #8 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Quote:
did u used this testpoint? br RNC_EBM | |
04-11-2006, 14:23 | #9 (permalink) |
Member: 38573 Status: Offline Thanks Meter: 0 | Yes, used test point. Must be i connect the test point wrong or wrong method. When you guys conncet the test point to the phone while USB is connected, does your WINXP detect a new device connect to the PC? I unlocked 2 units before, and all working, now using the same tool and method, doesnt wanna work anymore. |
04-11-2006, 14:28 | #10 (permalink) | |
Registered User Join Date: Aug 2003 Age: 41
Member: 36653 Status: Offline Thanks Meter: 336 | Quote:
1-connect test point 2-connect batterie (power on) 3-connect to PC (it will be detected ) 4-disconnect test point 5-unlock with p2k tools 3.4 | |
04-11-2006, 14:31 | #11 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | Maybe messed up drivers instalation? Try uninstall all P2K drivers (you have uninstaller in support), then try again, PC should detect phone. |
motorola v360 test point destroyed | aurelmarius1 | Motorola P2k | 0 | 07-20-2006 13:35 |
U8330 test point problem | sk3da | VygisToolbox | 6 | 04-15-2006 08:30 |
motorola L6 bad test point problem ??? | busta-gsm | Motorola Hardware Repair | 0 | 01-18-2006 09:46 |
MYC2 test point problem | Steph | SagMaster Team OLD Products | 7 | 09-18-2004 11:57 |
nec 606 test point problem PLEASE HELP | ali-g-string | NEC | 12 | 07-14-2004 10:39 |
