Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Dongle Problems (USB-Smart)
Dongle Problems (USB-Smart) Dongle probelms and installation support
Old 05-06-2006, 13:49   #1 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 770
UFS and USB-smart problem
i am having a problem with my USB-smart dongle..
i have a P4 1.5Ghz system with MSI -PM8M-V motherboard using via chipset ..
my ufs is working Ok but when i connect my USB-smart and try to run the SEMC tool and interface as UFS Twister then it gives error that (cannot connect to UFS Twister)..
please help me ...
my motherboard link
http://www.msi.com.tw/program/produc...il.php?UID=683
Old 05-06-2006, 14:17   #2 (permalink)
Registered User
.::Moby World::.'s Avatar
Member: 47936
Thanks Meter: 20
I have this problem before
i solved it by uninstall new ufs drivers and use the old one thats all
br
Old 05-06-2006, 14:23   #3 (permalink)
Member: 90236
Thanks Meter: 4
Just copy ufs drivers from saras soft directory to directory where you have installed usb smart and your problem gone.
Old 05-06-2006, 14:55   #4 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
http://forum.gsmhosting.com/vbb/showthread.php?t=290069
Old 05-06-2006, 16:32   #5 (permalink)
Member: 85248
Thanks Meter: 2
my idea you use higher version ufs2xx.dll and you must replace your ufs2xx.dll with usb-smart's ufs2xx.dll
Old 05-07-2006, 07:54   #6 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
No just the conversion of what u said.Because old ufs2xx.dll is used in usb-smart folder replace it from ufs pack dll file
Old 05-09-2006, 02:44   #7 (permalink)
struggler's Avatar
Member: 208691
i did have that problem to.. just buy a hub and it will work.. msi motherboards is tricky.. they gat nvidia nforce on tham and that is what couse the problem. buy a usb hub and plug it in. install the drivers and it will work
Struggler
Old 05-09-2006, 13:10   #8 (permalink)
H_C_K's Avatar
Member: 109224
Thanks Meter: 6
or just detach other devices (like JAF Vygis etc.) I got that problem too but when detached other usb ftdi devices it worked
Old 05-16-2006, 04:43   #9 (permalink)
Member: 131118
Thanks Meter: 40
Lightbulb awwwwwwwwwwww done
Hi mates i copied ufs2xxx.dll file to SMEC folder
and now getting error message any more
u guys can try it
WBR
Ejaz Khan
Old 05-16-2006, 04:58   #10 (permalink)
Registered User
taihv's Avatar
Member: 40808
Thanks Meter: 10
One minute ago i have the same problem, can not connect SEMC_tool_Vxx via UFS interface, but with Sharp_tool_v50 it connect well! Then i found the problem is UFS2XX.dll file in SEMC_tool_Vxx folder, just delete it and everything will be OK! Let try!
Old 05-18-2006, 05:35   #11 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 101
replace UFS2XX.dll this inside semc with ver 3.1.6.1 now u not get error
Ufs 3 + Clone Hwk And Usb Smart mike_hodgson Sell ur Old and Used Stuff 2 06-28-2007 09:47
Unlock problem with V3x and USB-Smart Gavincol78 Motorola P2k 1 09-04-2006 19:33
After update to newtest UFS driver. USB-Smart cannot be connected to UFS. y2khjh SonyEricsson (USB-Smart) 1 06-27-2006 16:33
How to connect UFS and USB Smart Bmt_HR Samsung (USB-Smart) 12 03-24-2006 14:20
Page generated in 0.19652 seconds with 10 queries
