01-20-2010, 14:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India Ranchi
Member: 756180 Status: Offline Sonork: 100.1582554 Thanks Meter: 56 | NOKIA 5130c rm-495 SD & SL NOT SUPPORTED DON'T TRY Model: RM-495 (5130 Xpress Music) V 06.93/20-05-09/RM-495 (c) Nokia Production serial number 0 Product code Module code Basic production code Flash code Order number Long production SN 0 MCU SW V 06.93/20-05-09/RM-495/(c) Nokia PCI RFIC 06540601 DSP ICPR72_09w04 LCD SEIKO PPM V 06.93/20-05-09/RM-495/(c) Nokia /MH BT MCM 2222-143C Retu 16 Tahvo 22 Content Pack Content: mh_red/V 06.93/20-05-09/RM-495/(c) Nokia / IMEI: 354179039728351 V 06.93/20-05-09/RM-495 (c) Nokia IMEI: 354179039728351 Failed to Read 354179039728351 Searching loader rap3gv3_2nd.fg RAP3 Phone, Requesting... Requesting service authorization from server... busy, waiting... Requesting code authorization from server busy, waiting... Computing... busy, waiting... Sending RPL... C:\Program Files\GriffinTeam\MT-Box\rpls\354179039728351_sx4_sim.rpl NO NPC CERTIFICATE!!!! IMEI: 354179039728351 SKIPPED Certificate sent ============= Set FBus mode for info ============= VBat is 4.00V Vpp pin has 1.34V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode NO SERIAL COMMUNICATION WITH PHONE NOT SENDING SIMLOCK AND SUPERDONGLE CHECK CABLE! V 06.93/20-05-09/RM-495 (c) Nokia IMEI: 354179039728351 Failed to Read Procedure completed in 27 seconds Phone is in: Test mode Model: RM-495 (5130 Xpress Music) V 06.93/20-05-09/RM-495 (c) Nokia Production serial number 0 Product code Module code Basic production code Flash code Order number Long production SN 0 MCU SW V 06.93/20-05-09/RM-495/(c) Nokia PCI RFIC 06540601 DSP ICPR72_09w04 LCD SEIKO PPM V 06.93/20-05-09/RM-495/(c) Nokia /MH BT MCM 2222-143C Retu 16 Tahvo 22 Content Pack Content: mh_red/V 06.93/20-05-09/RM-495/(c) Nokia / IMEI: 354179039728351 V 06.93/20-05-09/RM-495 (c) Nokia IMEI: 354179039728351 Failed to Read 354179039728351 Searching loader rap3gv3_2nd.fg RAP3 Phone, Requesting... Requesting service authorization from server... busy, waiting... Requesting code authorization from server busy, waiting... Computing... busy, waiting... Sending RPL... C:\Program Files\GriffinTeam\MT-Box\rpls\354179039728351_sx4_sim.rpl NO NPC CERTIFICATE!!!! IMEI: 354179039728351 SKIPPED Certificate sent ============= Set FBus mode for info ============= VBat is 4.00V Vpp pin has 1.34V, Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Test mode NO SERIAL COMMUNICATION WITH PHONE NOT SENDING SIMLOCK AND SUPERDONGLE CHECK CABLE! V 06.93/20-05-09/RM-495 (c) Nokia IMEI: 354179039728351 Failed to Read Procedure completed in 27 seconds o/40; V 06.93/20-05-09/RM-495 (c) Nokia IMEI: 354179039728351 Failed to Read |
The Following User Says Thank You to Shahid_Toshiba0 For This Useful Post: |
Nokia 5130c rm-495 error whilw flashing , how to solve phone dead??? | svchost | MT-BOX | 26 | 07-19-2011 14:11 |
NOkia 5130c Rm-495 Fbus piouts Need Urgent.? | communication_expert | Nokia Hardware & Hardware Repair | 11 | 04-09-2011 15:26 |
How to unlock Nokia 5130c RM-495 ? | gsm_unlock2 | MT-BOX | 6 | 02-16-2011 17:53 |
Nokia 5130c rm-495 contact service | ramoon20 | Cyclonebox | 6 | 03-05-2010 12:58 |
DOES MX-KEY SUPPORT NOKIA 5130c-2 RM-495 UNLOCKING AND SL REPARING?:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 06-04-2009 19:03 |
