11-30-2006, 11:39 | #2 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 42
Member: 83793 Status: Offline Thanks Meter: 0 | Please try again to connect to the phone. If it can't connect in few tries please go to download area, schematic directory and download C55x ELLE adapter.pdf. This simple circuit solves the boot problems. |
11-30-2006, 15:49 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: all over the world Age: 46
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | Im already downloaded schematic from support but Im confused because both side of connector are female I dont understand????. if is an adapter one side must be male and other female correct me if Im wrong. if possible please upload layout or pcb txs a lot br Last edited by wynasoft1; 11-30-2006 at 16:12. |
12-01-2006, 10:38 | #7 (permalink) |
Product Supporter Join Date: May 2002 Age: 54
Member: 12088 Status: Offline Thanks Meter: 4 | I uploaded schematic and manual which is more easier to understand then ps2 to ps2 adapter schematic. On some Elle phone you can not enter boot without this adapter. You have dir manuals in download area. |
12-01-2006, 16:46 | #9 (permalink) |
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | well Im did It all but not lucky impossible boot this phone I used battery and power adapters but same problem any other advice. txs a lot br |
12-02-2006, 17:51 | #11 (permalink) |
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | yes ic is labeled in this way. P8830G MM74HCT04N MC74HCT04N AND RESISTORS 22K 20% TOLERANCE AND 100NF. Im check schematic many times I dont know what is wrong. txs for answer. br |
12-04-2006, 10:09 | #12 (permalink) | |
Member: 12088 Status: Offline Thanks Meter: 4 | Quote:
We will contact you soon, but I am afraid that we will need this phone in our hands to find out what is problem. Please tell me do you have this problem with any Elle or only with this specific phone? | |
12-05-2006, 16:18 | #14 (permalink) |
Member: 83793 Status: Offline Thanks Meter: 0 | Please try the C551 or C552 with and without the adapter. If the adapter is OK, then it should work with and without adapter. This way you can verify that adapter is OK. |
12-09-2006, 19:53 | #15 (permalink) |
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | adapter solved tested with c55x but my elle not detected maybe is different hardware. Starting boot procedure... Phone detected! Waiting response... Error while connecting to phone txs a lot br Last edited by wynasoft1; 12-09-2006 at 21:07. |
7610 charger detected but not charging... | Burnt Cobba | Nokia Hardware & Hardware Repair | 6 | 08-23-2006 03:51 |
New SonyEricsson T 230 phone detected but nothing highlighted | bcnboy | Cruiser Suite | 13 | 05-18-2004 13:59 |
a55 can detect but cannot flash | bengong | Siemens-Benq RingTones and WallPapers | 0 | 06-25-2003 22:21 |
Emmi Droid Box detected but cant connect to Phones | kingbode | Motorola Old Legacy (EMMI) | 2 | 05-31-2003 17:26 |
