02-17-2005, 11:04 | #16 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | Quote:
02-25-2005, 23:55 | #20 (permalink) | |
Freak Poster Join Date: Jul 2003 Location: UK Age: 56
Member: 33320 Status: Offline Thanks Meter: 6 | Quote:
02-27-2005, 12:29 | #21 (permalink) | |
No Life Poster Join Date: Apr 2003
Member: 25806 Status: Offline Sonork: 100.78148 Thanks Meter: 2,915 | Quote:
hi , this is not a furious section and frd try to invest some money . Buy Redbox your problem will be solved. br tahir | |
02-27-2005, 12:45 | #22 (permalink) | |
And he is 100% write... I also use Frre Furios Nec instead of red box...try it , you will gain time | |
03-03-2005, 20:50 | #24 (permalink) | |
Go to www.sws-redbox.com and u will find all nec drivers for wich they have made unlock posible... As for cable..; use nec 341i cable...same for all nec+sharpGX15 ... and who know other platforms..... | |
03-04-2005, 18:06 | #25 (permalink) | |
Freak Poster Join Date: Sep 2003 Location: Paradise Age: 60
Member: 39477 Status: Offline Thanks Meter: 14 | Quote:
03-05-2005, 20:59 | #26 (permalink) | |
you have to: login go to nec Driver Usb Here it is named N401iusb.zip For login... see with julvir | |
03-22-2005, 02:51 | #28 (permalink) |
No Life Poster Join Date: Jan 2005 Location: NEW DELHI, INDIA Age: 50
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | I am new to Red Box I want to know to unlock the nec E-606, E-808 I have to open the phone and connect wires on the board according to the pics I got from Red Box, But which cable to use and cant i read codes without opening the phone and soldering wires? and after soldering the wires Should I have to use wires? |
03-22-2005, 21:07 | #29 (permalink) |
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | you must open that phone sir and how to do with cables??? u find schematics on sws-redbox.com if i am write things are like this 8-gnd 6-tx 5-rx so u can take nec cable u have already, open, don't unsolder cables , but solder new ones and solder them to you're phone Best luck here all pinout's u need http://pinouts.ru/pin_CellularPhones.shtml |
UPDATE - 22 06 05 SwS TOTAL NEC COMMANDER 3,2 | julvir | Redbox | 39 | 12-13-2007 07:44 |
SwS TOTAL NEC Commander v2.0.exe | Lipper | NEC | 3 | 05-06-2006 08:19 |
-UPDATE - 28 MARCH 05 - - SwS TOTAL NEC COMMANDER 3,1: N830 | julvir | Redbox | 26 | 09-14-2005 12:48 |
UPDATE - 5 jan 05 - SwS TOTAL NEC COMMANDER 2,8 : N830 | julvir | Redbox | 16 | 01-14-2005 00:40 |
update - TOTAL NEC COMMANDER v2.0 : | julvir | Redbox | 13 | 07-13-2004 18:43 |
