05-19-2004, 00:15 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: London Age: 46
Member: 42036 Status: Offline Thanks Meter: 6 | How to unlock e808? Many thanks. |
05-19-2004, 00:22 | #2 (permalink) | |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Quote:
hello, yes you can use cable you use for 606, connect TX on 3v you no need external power | |
05-19-2004, 22:39 | #3 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: ...where eagles fly...
Member: 19267 Status: Offline Thanks Meter: 101 | Quote:
05-20-2004, 01:56 | #5 (permalink) | |
take again from web site , i have change picture for is more easy to understand | |
05-20-2004, 06:04 | #6 (permalink) |
Member: 19267 Status: Offline Thanks Meter: 101 | IF YOU WANT TO SUPPORT YOU PRODUCTS PLS DO ON THE MEMBER PAGE EVERYTHING IS QUITE UNDERSTOOD I CAN LOCATE THE TESTPOINT ON THE PHONE BUT THE QUESTIONS AM ASKING ARE: - WHICH CABLE DO I USE TO UNLOCK 606 AND 808? -IS IT THE SAME CABLE FOR UNLOCK THAT I WILL USE FOR THE TEST POIT? THIS QUESTIONS GOES FOR BOTH 606/808 I THOUGHT YOU SHOULD FEEL FREE TO SUPPORT YOUR PRODUCTS VERY WELL SO AS TO ENCOURAGE WIDER MARKET OR ARE YOU SATISFIED WITH THE SALES SO FAR? |
05-20-2004, 06:25 | #7 (permalink) |
No Life Poster Join Date: Apr 2003 Location: inside iPhone Age: 50
Member: 26011 Status: Offline Thanks Meter: 38 | forget about 3v cable 5v cable Just connect Rx Tx and ground and press unlock. to unlock it will take 5 seconds. if your phone is new version it will show phone is unlocked . but redbox cannot unlock new version NEC phones. Thank you. |
05-20-2004, 06:41 | #10 (permalink) |
Member: 26011 Status: Offline Thanks Meter: 38 | Nothing any special cable for nec. you can find a opened cable in redbox package you can use it for nec phones. Red wire is RX White wire is TX Green+Orage both wires are Ground. for rx tx ground you can use any com cable( T191 db savy) Regards. |
05-20-2004, 06:46 | #11 (permalink) |
Member: 19267 Status: Offline Thanks Meter: 101 | now u gave 2 types of cables does both work perfectly for this nec 606/808, assumming I want to use the db savvy cable is alrite as well rite |
05-20-2004, 10:19 | #12 (permalink) |
No Life Poster Join Date: Oct 2003 Location: @@Afsus_ tunisia-sat@@ Age: 63
Member: 42750 Status: Offline Thanks Meter: 114 | Model: NEC E808 NEC Temporary Unlock: Put a 2G Simcard and turn ON the phone. #4960*xxxxxxxx# *4960*xxxxxxxx*xxxxxxxx# Turn OFF and ON again. xxxxxxxx = any numbers Remember the xxxxxxxx you used. You will need to use same code in the furure. Attention: - This unlock method ONLY works with one Simcard. If you change to another Simcard, you will have to unlock again! - This method depends on the firmware version. If didn't work only a cable soluction can help you. |
05-20-2004, 13:31 | #13 (permalink) | |
MAN look ON SUPPORT page , download the NEW picture , you see excatly what to connect , use cable from redbox , and connect like is explain in picture, if you can not find test point in phone , i can not come and show you , i think picture is allready ok but EASY PICTURE is on support zone With color to Connect ! so please check it !! | |
05-20-2004, 14:04 | #14 (permalink) | |
Member: 26011 Status: Offline Thanks Meter: 38 | Quote:
@ bakarioss dont recommend this method for unlock NEC phones, becoz after unlock NEC phones with this method phone will restart every 30 seconds and you have to enter the codes again,, again. To Julvir, i thinhg we all buy redbox software specially for Unlocking NEC phones. but redbox still cannot unlock latest version E606 phones and no any updates for E616. so please give any new updates for nec phones. also we cannot check what is the version in locked nec phones. -then i want to ask why 3G phones after unlock, when insert a sim card phone will automatically swiched On. this problem not only for NEC phones this same problem arrive Motorola A835 also. Regards. | |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
how to flash E808 | ersa | NEC | 5 | 04-09-2007 15:05 |
help me to unlock e808 ............. | cmshareef | NEC | 2 | 03-20-2005 09:15 |
how to unlock NEC e808 ?? | imth | Redbox | 2 | 08-20-2004 10:41 |
how to unlock e808 with redbox? | infogsm | Redbox | 4 | 07-16-2004 19:06 |
