09-06-2005, 20:02 | #16 (permalink) | |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | Quote:
Read AGAIN flash please , and send again to me , last flash was not correct BR | |
09-06-2005, 20:39 | #17 (permalink) | |
Banned Join Date: Jun 2005 Location: in my office Age: 47
Member: 154808 Status: Offline Thanks Meter: 1 | Quote:
10-15-2005, 20:15 | #20 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Denmark Age: 55
Member: 18805 Status: Offline Thanks Meter: 27 | Quote:
WBR Falck | |
11-09-2005, 07:54 | #23 (permalink) |
No Life Poster Join Date: Sep 2002 Location: mauritius
Member: 15162 Status: Offline Thanks Meter: 61 | @splato Make new cable and label it pin 1 pin2 etc....Post also what error you get i will help you . The only problem i get is all c4-2 i have try is unsupported version.always problem to read flash from c4-2 ,myv56 . TRY THIS:- EXAMPLE FOR MYC3-2 Hi all Here we go again in details:- MAKE A NEW CABLE AND DON'T LOOK AT COLOUR WIRE . LABEL EACH WIRE PIN1 ,PIN2 ,PIN3 ,PIN 4,PIN 5 ,PIN 6 ,PIN 7 ,PIN 8 DETAILS RJ45 PIN 1 IS FOUND ON THE RIGHT HAND SIDE OF SWS BOX THAT IS ON THE RED LIGHT SIDE AND THE USB PORT. RJ45 PIN 1 AND RJ45 PIN8=GND GOES TO PHONE CONNECTOR RJ45 PIN2=TEST POINT RJ45 PIN3=TEST POINT RJ45 PIN4=RX GOES TO PHONE CONNECTOR RJ45 PIN5=TX GOES TO PHONE CONNECTOR RJ45 PIN6=TEST POINT RJ45 PIN7=TEST POINT LABEL EACH WIRE PIN1 ,PIN2 ,PIN3 ,PIN 4,PIN 5 ,PIN 6 ,PIN 7 ,PIN 8 Unlock Myc3-2 testpoint Open this link http://forum.gsmhosting.com/vbb/atta...chmentid=36297 now do this:- On yellow wire solder =rj45 pin 7 on black wire solder =Rj45 pin 6 On blue wire solder=Rj45 pin 3 On red wire solder=Rj45 pin 2 .If you read all well You should get it work 100% Hope this can help u . Cheers Djyash |
11-09-2005, 21:50 | #24 (permalink) |
No Life Poster Join Date: Oct 2000 Location: Split / Zagreb, Croatia Age: 53
Member: 2236 Status: Offline Thanks Meter: 58 | To Djyash: I already have made the cable by your instructions in some other post... and those instructions are exactly the same as these here above my post... and since I do electronics for over 15 years, I can say that I have made the cable exactly like you wrote and I can confirm that it does not work on C4-2 Always receiving the same message over and over again: Reading phone info: BAD CONNECTION CHECK YOUR TESTPOINTS - Phone firmware : 5701000273456 KE3, UC: 070705 1002 - Phone IMEI : 3558... etc... - Hash table : 17 51 01 - Phone code : 0000 Problem is not with C3-2... it is with C4-2... Waiting for a solution... lucky I get these C4-2 phones once a month |
11-10-2005, 11:31 | #25 (permalink) |
Member: 15162 Status: Offline Thanks Meter: 61 | Had same problem like you my friend. One last thing you must try is change your lpt cable to shorter one . You must also reduce the testpoint wire .make the testpoint wire to 4-5 cm .solder wire directly on board.try it and let me know. Hope this can help you spalato. cheers Djyash |
11-11-2005, 16:09 | #26 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Brasil Age: 60
Member: 99180 Status: Offline Sonork: 1575711 Thanks Meter: 8 | C4-2 1- Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5324500671700 KE3,UC: 070705 1003 - Phone Imei: 355872001939233 - Hash Table : 17 51 01 - Phone Code : 0000 2- Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5172460705389 KA3,TH: 170605 0753 - Phone Imei: 357161000207869 - Hash Table : 03 00 02 - Phone Code : 0000 3- Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5314007020567 KE3,UC: 070705 1002 - Phone Imei: 355872001122129 - Hash Table : 17 51 01 - Phone Code : 0000 PLEASE HELP ME ICQ 315214447 MSN: [email protected] Last edited by Vinicius; 11-11-2005 at 16:54. |
11-16-2005, 23:29 | #27 (permalink) |
No Life Poster Join Date: Mar 2003
Member: 24435 Status: Offline Thanks Meter: 4 | same problem i have with myc-4 and wonu phones...conector/cable is same like for other phones...and still no answer for this: Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5505234860119 JA3,SA: 100804 1955 - Phone Imei: 353825000832975 - Hash Table : 22 00 00 - Phone Code : 0000 Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5505234860119 JA3,SA: 100804 1955 - Phone Imei: 353825000832975 - Hash Table : 22 00 00 - Phone Code : 0000 Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5505234860119 JA3,SA: 100804 1955 - Phone Imei: 353825000832975 - Hash Table : 22 00 00 - Phone Code : 0000 Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5505234860119 JA3,SA: 100804 1955 - Phone Imei: 353825000832975 - Hash Table : 22 00 00 - Phone Code : 0000 Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5505234860119 JA3,SA: 100804 1955 - Phone Imei: 353825000832975 - Hash Table : 22 00 00 - Phone Code : 0000 Searching Phone..Found. Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Frimware : 5505234860119 JA3,SA: 100804 1955 - Phone Imei: 353825000832975 - Hash Table : 22 00 00 - Phone Code : 0000 hmm...i try on jtag2.7 and it is same...maybe some provider have done aditional protection and boot loaders can not be loaded into the phone... PS : Read Tutorial before using Flash tab. Searching Phone..Found. Reading Phone Info : - Phone Frimware : 5505234860119 JA3,SA: 100804 1955 - Phone Imei: 353825000832975 - Hash Table : 220000 Loading loader to Phone.BAD CONNECTION CHECK YOUR TEST POINT!!! |
01-01-2006, 11:50 | #28 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 42
Member: 138809 Status: Offline Sonork: 100.99886 Thanks Meter: 79 | Reading Phone Info : BAD CONNECTION CHECK YOUR TEST POINT!!! - Phone Firmware : 5234618950510 JA3,SA: 100804 1955 - Phone Imei: 353825000404874 - Hash Table : 22 00 00 - Phone Code : 0000 same prob |
02-02-2006, 06:43 | #30 (permalink) |
Member: 15162 Status: Offline Thanks Meter: 61 | If you are having problem please try to put your finger on the testpoint.For me no problem it works .when i solder wire on board only i get error,when i put my finger on it ,it works. Try it and let me know . Cheers Djyash |
unlock OLD Sagem C4-2, where is the probleme | JAVA Good | SMTi | 4 | 08-13-2009 07:12 |
sagem C4-2 | ziober | SMTi | 1 | 06-26-2007 08:22 |
sagem c4-2 problem? | YeTi | Redbox | 3 | 01-13-2006 21:46 |
