06-11-2005, 09:40 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: P A K I S T A N Age: 49
Member: 75644 Status: Offline Thanks Meter: 5 | furious team flash error in k500i flash with k500i file 's after flashing without sim it ok and asking for insert sim but when i put sim i got this error { configuration error.please contact your service provider or service center.} any solution Last edited by mas comm; 06-11-2005 at 16:23. |
06-11-2005, 12:45 | #3 (permalink) | |
Member: 75644 Status: Offline Thanks Meter: 5 | Quote:
the files i used r (k500_main_eu1_R2AG001_CID29.BIN k500_FS_US1_R2AG001_CID29.bin)))))))))) --------------6/11/2005 2:52:11 PM-------------- Getting data from server... Connection ok! Data recieving... Credits: 6427 Counter: 3573 Shortly press Power button! Detected SonyEricsson: K700/K300/K500/S700/Z500. Status Ok, OTP Close, CID29, PAF1 IMEI: 354260-00-341890 Flash file CID:29 Flashing 74 blocks... address: 452C0000, block: 74/74 D:\Program Files\FuriouS BOX II\Flashes\K500i_FS_US1_R2AG001_CID29.BIN flashed successfully Flash Finalization Started! Wait while process will be finished! S700 recognized! Error! CsLoader not accepted! Execution Time - 00:07:24 Error: 0x006666 | |
08-19-2005, 17:53 | #4 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 89773 Status: Offline Thanks Meter: 4 | HELP HELP HELP flash with k500i file 's after flashing without sim it ok and asking for insert sim but when i put sim i got this error { configuration error.please contact your service provider or service center.} any solution |
08-19-2005, 19:34 | #5 (permalink) | |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,583 | Quote:
1. Flash main 2. Flash fs 3. Do finalisation. Each step done separetly. Br | |
08-23-2005, 07:51 | #6 (permalink) | |
No Life Poster Join Date: Apr 2005 Age: 47
Member: 135671 Status: Offline Thanks Meter: 45 | Quote:
I 'm see message configuration error.please contact your service provider or service center I 'm can not see finalisation. Where button i can to do it. Help me Please. Best & regards | |
08-23-2005, 07:58 | #7 (permalink) |
No Life Poster Join Date: Dec 2003 Location: United Kingdom, ENGLAND
Member: 47774 Status: Offline Thanks Meter: 185 | 1. Select main file only like K300_MAIN_EU1_R2AL029_CID36.BIN for ex and press FLASH. Shortly press Power button! Detected SonyEricsson: K700/K300/K500/S700/Z500. Status Ok, OTP Close, CID36, PAF1 IMEI: 355795-00-216485 Flash file CID:36 Flashing 206 blocks... address: 44C6A3E0, block: 206/206 D:\K300_MAIN_EU1_R2AL029_CID36.BIN flashed successfully Execution Time - 00:05:20 Done! 2. Press flash and let operation finish and after remove battery and put back. 3. Select fs file only like K300_FS_EU1_R2AL029_CID36.BIN for ex and press FLASH. Shortly press Power button! Detected SonyEricsson: K700/K300/K500/S700/Z500. Status Ok, OTP Close, CID36, PAF1 IMEI: 355795-00-216485 Flash file CID:36 Flashing 73 blocks... address: 45280000, block: 73/73 D:\K300_FS_EU1_R2AL029_CID36.BIN flashed successfully Execution Time - 00:02:06 Done! 4. Press flash and let operation finish and after remove battery and put back. 5. Select finalisation only and press FLASH and select YES on messagebox. Remove battery and put back. Shortly press Power button! Detected SonyEricsson: K700/K300/K500/S700/Z500. Status Ok, OTP Close, CID36, PAF1 IMEI: 355795-00-216485 Flash Finalization Started! Wait while process will be finished! K700/K500 recognized! CsLoader Accepted Ok! System Initialization. Please Wait... Getting data from server... Connection ok! Data recieving... Sign 1 ok. Sign 2 ok. CsLoader Unlocked! Flash Finalization - successfull !!! Execution Time - 00:00:34 Done! NOTE: CID 36 files can be used on K300i only. If u intend to flash CID firmwares on k300 then u must use cid 29 to cid 36 transformation file. ( u found Finalization Flashing down open ur eyes please ) BestRegards, FuriouSTeam Last edited by .:Morpheus:.; 08-23-2005 at 08:08. |
08-23-2005, 08:06 | #8 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Sahiwal Punjab , Pakistan
Member: 123133 Status: Offline Sonork: 100.999 Thanks Meter: 911 | ok one more method is to kill Configurtion error tested by me flash the phone with fs and fs put the fs file into main place and put the same file into fs place. flash the phone it will be ok after flash Br Kuku |
Need flash file for Chinees Sony ericson K810i | Unicom | Infinity-Box | 1 | 12-24-2008 08:04 |
Need flash file for Chinees Sony ericson K810i | Unicom | Chinese Models & Cloned Phones | 0 | 12-24-2008 06:04 |
can flash VK4000 in furious | conancin | FuriousGold | 0 | 07-15-2007 17:54 |
Lobster 544 Error in furious gold | maxieboy | FuriousGold | 3 | 02-23-2007 05:45 |
can be use (vygis) LG 2g flash file in furious | aukonline | FuriouS II | 3 | 03-17-2006 15:30 |
