12-02-2004, 23:44 | #17 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Europe
Member: 69725 Status: Offline Thanks Meter: 36 | GX25 unlock Phone is unlocked... thanks A LOT really!!! I will describe some things here which I didn't know... What you need to unlock gx25? - Furious box - USB NEC M8 cable - Fully charget battery - Installed drivers for GX15 ( http://sharp.gsm-si.net/gx15/drivers/gx15drivers.zip ) - step by step... you need to have NEC USB cable and GX25 phone if you want to install this correctly How to do it now? - When you install drivers, check in Control panel->Device manager->Ports(COM&LPT) for SHARP GSM GPRS USB DRIVER ->right click ->Properties->Port settings->Advanced->Read COM port number - You will be possibly prompted for modem instalation maybe before this or later... only press next and continioue anyway... - Open Sharp from Furious and choose gx15 - Phone powered ON or OFF (I don't remember anymore, because I tried hundred times ) - press UNLOCK - Follow the instructions! - All OK! If you got errors on 3% choose different port... don't panic if you use USB cable and choosing COM port Thanks to all supported me! Regards Gogy |
The Following User Says Thank You to GoGy For This Useful Post: |
12-02-2004, 23:49 | #18 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: United kingdom Age: 64
Member: 26440 Status: Offline Thanks Meter: 6 | Quote:
12-02-2004, 23:56 | #19 (permalink) |
Member: 69725 Status: Offline Thanks Meter: 36 | I think that more people should report how did they solve their problems (just as I did it below)... and it would be much easier for everybody It is midnight now... it is better to go for some sleep |
12-24-2004, 09:44 | #20 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Slovenia Age: 48
Member: 15385 Status: Offline Thanks Meter: 9 | How to? Hi to all! I read a lot of threads about how to unlock Sharp gx25. I have USB cable, I have thia AllSharp program, but don't have drivers to instal USB cable for GX 15. Does anyone know where can I get those drivers or. how can I install it? Thanks in advance for any help. BR, Dejan |
06-07-2005, 07:28 | #21 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | @GoGy big thanx to clear us that how to chek about installation driver i try lots of time and also search in forum but maximum person said that it unlock with com cable and in the end i read ur post to unlock through usb and try it and i sucess it |
06-07-2005, 07:46 | #23 (permalink) |
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | @pchelpsi yes dear u r right before reading this thread i install driver several time but not sucess and i leave it unlock through usb but when i read this post than i hope and after few hour and i waste more my mind and in the end i sucess so it's not very easy to unlock through usb cable |
06-15-2005, 19:15 | #26 (permalink) | |
Junior Member Join Date: Dec 2004 Age: 46
Member: 97653 Status: Offline Thanks Meter: 0 | Quote:
Any instructions? Any program to do this? Thank you in advance... GaS | |
06-17-2005, 10:25 | #29 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Gujranwala Pakistan Age: 48
Member: 71190 Status: Offline Sonork: 100.1580485 Thanks Meter: 87 | i have unlock a gx25 with this way 1st,, i instal driver of gx15 computer will restart after instal driver, 2nd ,conect usb cabel of nec with coumpter and set its requier a driver slect next and browes in drive C/program files/SHARP GSM GPRS USB Driver/drivers/win98, after it click next and finsh , after it right click on MY COMPUTER and click properities after it click device manger see in last if ther is unknown device show click it and reinstal driver after instal driver click ports (com & lpt) option in device manger u will see SHARP GSM GPRS USB device (com 6) now open usr (universal simlock remover) slect sharp , open software "sharp GX15 GX30 TM 100 unlocker" slect gx15 and slect com 6 then click unlock a other menu will open in window and **** will show on your mobile lcd in other menu see all instructions , just apply all instroctions your set will unlock ( set will b on with out simcard and battery must full charged and use window 98 ) thats all " regards SHAHNAWAZ GONDAL |
06-24-2005, 00:24 | #30 (permalink) |
Freak Poster Join Date: Jan 2005 Location: France
Member: 103520 Status: Offline Thanks Meter: 17 | someone try to set the diag mod manualy with the gx10 procedure ? 1- Press 0, 3, top right key and Red key together for about 3 secs until a white display is shown. 2-Press 0, 1, 2, 3, top right key, 1, in sequence. I have no phone here to try if someons can test it let me know. What's the BT procedure for this phone ? |
lg u310 can be unlocked by furious gold | aleem26 | LG | 6 | 07-09-2011 15:20 |
lg u400 can be unlocked with furious?(Solved) | GSMman187 | FuriousGold | 5 | 10-21-2009 08:33 |
Sharp GX25 can be unlocked?? | zakiyyboss | FuriouS II | 1 | 11-06-2006 17:41 |
can anybody confirm if z105 can be unlock by choosing x430 in ust | ashvin | QUALCOMM Models (3G) | 2 | 08-06-2005 20:55 |
is this version can be unlocked with furious 3G free ?? | chavrotti | NEC | 21 | 01-03-2005 11:44 |
