11-20-2004, 20:29 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: The Netherlands Age: 44
Member: 66947 Status: Offline Thanks Meter: 1 | Help with NEC N341i unlock... Hi! I have 3 pieces NEC N341i to unlock. But when i connect USB cable and power on phone the computer ask for drivers. Then i give the link to the driver map with drivers Win NT. Maybe this is wrong? I use Win XP. Then the computer ask another few times for drivers and i give the link to the map with drivers again and again. After a few times the computer says that the Hardware is ready for usage. When i look in PC configuration i see that NEC is connected on com-port number 4. When i open program and select N341i and press read codes the program says: searching for phone on com-port 4, 5, 6, 7, 8, 9 en then restarts and never find phone on com-port 4. Can someone give me advise? Regards, P. |
11-21-2004, 11:04 | #3 (permalink) |
Member: 66947 Status: Offline Thanks Meter: 1 | Hi, the Win NT driver map, is located in furiousdongle>nec>usbdrivers>n341i When i unzip n341i file, i get the map Win NT. So i have used drivers from Furious Dongle. Regards, Peter |
11-23-2004, 15:05 | #4 (permalink) |
Member: 66947 Status: Offline Thanks Meter: 1 | Well i have it working on a laptop without normal rs232 comports. But the codes i get on the two N341i phones are all FFFFFFFF what is this? Regards, Peter |
02-03-2005, 01:27 | #9 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Cebu, Philippines
Member: 15652 Status: Offline Thanks Meter: 344 | this is very helpful. tnx a lot steve. I could only suggest that you put the instruction with the software so that i wont go around scampering on the procedure. |
02-03-2005, 05:30 | #10 (permalink) |
Product Manager Join Date: May 2001 Location: Los Angeles
Member: 4584 Status: Offline Sonork: 100.69564 Thanks Meter: 15,093 | But if you see in folder : \FuriouS Dongle\furious\nec\readme.txt You can see inside the solution how to enter the code . Best regards, Steve. |
nec n341i unlocking problem | gpyson | NEC | 7 | 09-08-2006 18:09 |
Problem With Nec 3g Unlocker/multi Unlocker | lemor | FuriouS II | 0 | 02-03-2005 12:12 |
Need help with NEC DB2000 | Disaster | Various | 6 | 05-12-2001 00:50 |
