12-21-2005, 09:17 | #2 (permalink) |
No Life Poster Join Date: Nov 2005 Location: .:GSM WORLD:.
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | LG 8120 Flashing... using F-BOX 1-> Connect phone(power off) using the LG Special USB+RJ45 Cable. 2-> Goto SEMC Flasher in main Furious Software SElect LG 8120. 3-> Select Com-port for ur Box. 4-> Choose the Flash Files (all 4 files at a time). 5-> on pop-up dialog box clickon "yes". 6-> power on Phone shortly with battery inserted in it. 7-> it will start flashing process ................. 8-> ENJOY>>>>>>>>>>>>>>>>>>>>>>>>>> |
12-21-2005, 10:25 | #3 (permalink) |
Member: 201343 Status: Offline Thanks Meter: 26 | I have three cables like, lg 7050, 510,8110. Which one is correct cable to flash lg u8120....... i go the support area there are so many flashing files... Example.. v 8120_v101_DENMARK ,, ,, _,,,,,,_ISRAEL ,,,,,,,,,_v104c AUSTRIA v 8120_v105+ ,,, ,, _v105+_ ITALY ,,,,,,,,,,,,,105_ UK V109 _ HK how to select the flies... please help me |
12-21-2005, 10:35 | #5 (permalink) | |
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Quote:
12-21-2005, 14:35 | #6 (permalink) |
Product Manager Join Date: May 2001 Location: Los Angeles
Member: 4584 Status: Offline Sonork: 100.69564 Thanks Meter: 15,093 | U can do like this : http://www.furiousbox.com/inside.php...&model=LG3GNEW But you choose files for 8120 BR. Steve. |
12-21-2005, 15:17 | #7 (permalink) |
Member: 201343 Status: Offline Thanks Meter: 26 | on pop-up dialog box clickon "yes". 6-> power on Phone shortly with battery inserted in it ERROR...... The com is the compliant. In my computer properties in device manager port is 22,23..is working The soft ware semi flasher com port is up to 3 to 14 only Help me the urgent........ |
12-21-2005, 15:28 | #9 (permalink) | |
Member: 201343 Status: Offline Thanks Meter: 26 | Quote:
6-> power on Phone shortly with battery inserted in it ERROR...... The com is the compliant. In my computer properties in device manager port is 22,23..is working The soft ware semi flasher com port is up to 3 to 14 only Help me the urgent | |
12-21-2005, 18:06 | #10 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,569 | Is simple..Download flash archive u like and flash all files inside. If u use EPI (MEANS CABLE WITH USB+COM GOT WITH FURIOUS) then check USE EPI select com1/com2 and speed 115200. If u use FTDI then check FTDI select com on which cable is installed and selcted desired speed to flash ... max 960Kbps. ALSO +5V must be enabled on BOX. Br |
12-22-2005, 12:41 | #11 (permalink) | |
Member: 203158 Status: Offline Sonork: 100.1592032 Thanks Meter: 358 | Do this Quote:
how to flash lg u8120 ? with slaver | Faisal_Computer | powerflasher | 5 | 09-05-2005 07:55 |
Could explain how to unlock LG U8120 version V105_20041207? | todoportable | Cruiser Suite | 2 | 07-23-2005 13:06 |
how to unlock LG U8120 with Red box II | shailesh | Redbox | 2 | 05-18-2005 21:58 |
How to unlock LG U8120 v102 with Griffin server v1.22 | SoftMobile | Griffin | 4 | 12-20-2004 17:58 |
how to unlock lg u8120 with redbox?? | infogsm | Redbox | 13 | 09-28-2004 14:26 |
