NEC PLUGIN HW-ID Problem.. I've been using FuriousBox2 for quite sometimes now, and this is the first time that i have encountered a problem, it all started when i reformat my laptop,when i open FuriouS Box II Client v1.0.0.142 i cannot enter NEC PLUGIN HW-ID. A friend of mine told me to use the old version of FuriouS Box II Client, well, i can't confirm if its working cause the old version is no where to be found.. Please Furious Team,.:hack3r2k:., Help me solve my problem.. Thanks in advance.. |
use last version unistall from windows control panel erase any previus directory of F-Box reinstall F-Box start client check for Firmware, must be v2 |
ok, I'll try that and post the result, thanks for your quick reply... |
I have followed your instructions religiously, but whenever i try to open Furious Main v2235 the box NEC PLUGIN always appears, I enter the name and serial and then push activate. after that restart the software then open furious main v2235 again the box NEC PLUGIN appears, but before that my problem is i can't enter my hw-id in furious client, i can only get my key, that's all, please help me... |
Br;) |
Sir, i read the tutorial carefully, i can generate the key but i can't enter the HW-ID to the slot where it is alloted to, it does not allow me maybe it has something to do with the paidupdate, sir if you have the old installer before the paid update was introduce i would like to try that sir, pls give me link.. |
Br;) |
sir, thank you very very very much, you're such a great help, i did exactly what you say, uncheck system key only, and after that i have enter hw-id.. more power to you sir .:hack3r2k:. and keep up the good work....thanks. |
hi I am new here and I have a pbm with fb2 after the formatting of my PC and to install v1.0.0.2272 the software requires of me to activate the nec plugin and I cannot ecrire the hw-id on furiousclient to help me please |
hello when i am going to install new version 2272,client versions also new when goto system key always say invalid account ,but working at furious support,so plz help me mr steve,thanks. |
http://www.furiousbox.com/images/flag/flag-uk.gif When you run FuriouS BoX 2 software, it will ask you for registration name and serial number. You need to use the server again to obtain this Key. http://www.furiousbox.com/images/flag/france.gif Quant vous lancerez le logiciel FuriouS BoX 2 pour la premiere fois, un login et serial number vous sera demander vous utiliser le modules NEC3G. Vous devez utiliser le server pour obtenir cette clé dactivation pour le module NEC. http://www.furiousbox.com/images/guides/necact/2-p.gif http://www.furiousbox.com/images/flag/flag-uk.gif Now run FuriouS Client enter NEC PLUGIN HW ID and press connect. You receive your key in real Time. http://www.furiousbox.com/images/flag/france.gif Maintenant entrer votre NEC PLUGIN HW ID dans le FuriousClient.exe puis appuyer le bouton connect.Vous recevrez en temps réel la clé dactivation pour le module NEC. http://www.furiousbox.com/images/flag/flag-uk.gif Now enter data sent by server in NEC PLUGIN window also enter your username (SAME AS FURIOUSCLIENT). Press Enter Serial Button http://www.furiousbox.com/images/flag/france.gif Maintenant entrez le numéro de série obtenue avec le FuriousClient puis entre votre nom dutilisateur (COMME CELUI DU FURIOUSCLIENT). Appuyez sur le bouton Enter Serial http://www.furiousbox.com/images/guides/necact/4.gif You must restart FuriouS BoX software to finish the registration. Now the NEC PLUGIN is active in your FuriouS BoX. ____________ Vous devez redémarrer le logiciel pour valider lactivation du NEC PLUGIN. BR. Steve. |
thank you my friend yassirovic has who has regle the pbm by giving me the solution |
invalid i follow that instruction to the letter and all i get is account invalid how do i make my account valid surely only furious team can valid my account no ammount of installs uninstalls will fix that problem so what is wrong with my account. i am sick of waiting now so please hurry. |
Br;) |
