Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > FuriouS II
Old 04-07-2006, 10:33   #1 (permalink)
ziko's Avatar
Member: 16916
Thanks Meter: 3
Panasonic VS3 can't get unlock menu
Hi,
I tried to unlock and all pass OK, but after entering 5284** no UNLOCK MENU appear, but I'm back to root MENU.
Tried several times but no success, then I go to my friend which has Infinity he readed codes but when I put SIM phone find network (no wrong SIM message), then unlock menu appear and put unlock code, but I think phon was already unlocked without entering Infinity code...
Why I can't get UNLOCK MENU with Furious?
wbr
Ziko
Old 04-07-2006, 16:05   #2 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,132
Originally Posted by ziko
Hi,
wbr
Ziko
Just a little info: 52824** code appear only when phone is LOCKED.
Your problem was because you DON"T read instruction but you think that you know much better than software developers what to do.
So less ppl know what is this unlock method means so you need to follow unlock instruction exactly step-by-step because:
1. after you make unlock with software your phone TEMPORARY unlocked
2. when you power on phone with sim card after unlock 1st time you CAN"T see lock menu because phone NOT LOCKED at this time.
3. when you power off/on phone 2nd time you CAN see lock menu because phone already LOCKED.
summary: always make unlock exactly step by step.
Old 05-03-2006, 17:11   #3 (permalink)
Member: 6358
Thanks Meter: 10
If that is so, how come the phone says "invalid sim" when turned on with a different sim card, right after being unlocked? Shouldn't it be TEMPORARILY UNLOCKED?
Old 05-09-2006, 23:50   #4 (permalink)
Member: 68771
panasonic vs3 buuuu
with me the same... no menu to insert the 12345678 code....can we have some suportt please
Old 07-08-2006, 17:21   #5 (permalink)
ziko's Avatar
Member: 16916
Thanks Meter: 3
Second VS3 and same problem, why put some models when not worked, and believe me I know to read and make procedure as write in soft!!!
PHONE MUST BE IN TEST MODE !
Bypassing boot authority...
Boot authority bypassed.
Connecting...
Platform: NBG_LEOPARD_05.19.01.01SMARTI_SDB1SGOLDlit
Reading phone...
IMEI: 35640400xxxxxxx
FW version: Mmi:VS3-VA49,Sep22200510:43:49
Security: 00.11Sg(0002)
Searching for SP address...
Reading SP data...
Checking SP data...
Lock 0 active
Lock 1 inactive
Lock 2 inactive
Lock 3 inactive
Lock 4 inactive
Finalizing...
Unlock manual:
1. insert any SIM card into phone
2. switch ON the phone
3. switch OFF the phone
4. switch ON the phone, press 52824**
5. Enter unlock code
6. Switch OFF phone
Unlock code: 12345678
WORK DONE !
Old 07-12-2006, 14:33   #6 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
hi
this phone make me crazy ifollow the steps at the first and i enter 12345678 phone tell me " debloquer " unlocked and i power off the phone ( all is good )
but when i power on i c sim card not accepted and when i enter menu with 52824** don't c the lock network all is unlocked and phone not acept sim card.
any help plz
Old 07-26-2006, 00:50   #7 (permalink)
Member: 228703
Thanks Meter: 21
same probleme with my furious gold
Connecting...
Platform: NBG_LEOPARD_05.19.01SMARTI_SDB1SGOLDliteV1
Reading phone...
IMEI: 356404000591317
FW version: Mmi:VS3-VA47,Jul22200504:03:08
Reading SP data...
Checking SP data...
Lock 0 active
Lock 1 inactive
Lock 2 inactive
Lock 3 inactive
Lock 4 inactive
Finalizing...
Unlock manual:
6. Switch OFF phone
WORK DONE !
Time needed - 00:00:24
but with red box after do connect
Reading SP data...
Checking SP data...
Writing SP data...
Unlock manual:
6. Switch OFF phone
Operation time: 00:10.
Successfully done.
for not los time ido unlock
the redbox soft read unlock code=50048881
i put sfr sim,enter lock and finaly unlocked
sorry for my english
Old 07-27-2006, 18:32   #8 (permalink)
Member: 15022
Sonork: 100.53452
Connecting...
Reading phone...
Reading SP data...
Checking SP data...
Lock 0 active
Lock 1 inactive
Lock 2 inactive
Lock 3 inactive
Lock 4 inactive
Finalizing...
Unlock manual:
6. Switch OFF phone
WORK DONE !
Reading SP data...
Checking SP data...
Writing SP data...
Unlock manual:
6. Switch OFF phone
Successfully done.
Man with phones sent all is ok. Each period of time new sw appear. Simple sale us one phone with such pbs else cant help !
Old 07-28-2006, 00:33   #9 (permalink)
Cheater -Don't Deal with him-
infogsm's Avatar
Member: 18022
Sonork: 1574868
Thanks Meter: 192
Originally Posted by micmac
hi
any help plz
same problem with pana vs2 !!!
br
Old 08-01-2006, 05:58   #10 (permalink)
Member: 20953
Thanks Meter: 94
is it possible that the unlock menu does not appear because someone tried some codes toooo many times ????
I also followed procedure step by step on VS3 and turned on , off then on and 52824** and no unlock menu!!!
Old 08-01-2006, 21:40   #11 (permalink)
Member: 15022
Sonork: 100.53452
Is possible to be new fw phone so we need one such to update our soft.
panasonic VS3 unlock menu zapped FuriousGold 7 07-19-2008 10:59
Panasonic VS3 can´t unlock Mgsm FuriouS II 8 04-05-2006 15:43
GSMkey support Panasonic VS3, etc. - promo price buy one and get second FREE! FreeGSM Team Main Sales Section 0 01-18-2006 15:25
LG U8138 V107, Can't get into unlock menu, plz Help. Speedy LG 11 03-31-2005 06:14
Hlp- A100 after flashing can't get into menu? cpu486 VLSI, Conexant, Skyworks and Old Models 1 05-30-2003 11:18
Page generated in 0.23434 seconds with 9 queries
