12-20-2004, 22:02 | #1 (permalink) |
No Life Poster Join Date: Nov 2003 Location: www.thephoneclinic.com
Member: 44566 Status: Offline Thanks Meter: 7 | Prob With Nec Usb Drivers Pls Assist Or Xmas Will Be Cancelled Cheers Furious Pheeky |
12-20-2004, 22:53 | #2 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | first of all the phone must be powered off second the cable should b modified just see the attachment that i m sending u that will help to modify the cable. now the other problem that it is showing u so many ports it looks like that u have installed drivers with the phone powered on u should uninstall these drivers and after modifying your cable conect the phone without the battery if the u have modified the cable properly as shown in picture then the outer screen of your phone should become orange and you will see on your pc new hardware found look for drivers.DON'T click to search automatic do it manually from specified folder browce from your drive c. find the nec drivers open the folder choose the right model and install them atleast four times till it says new hardware found and it is ready to use. while installing the drivers u will see that the phone screen will trurn in to blue.if you haven't got the drivers then downlood the NEC SERVER CLIENT xtract the files u will see nec drivers. best regards |
12-20-2004, 23:33 | #3 (permalink) | |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 13808 Status: Offline Thanks Meter: 163 | Quote:
bR | |
12-21-2004, 16:17 | #4 (permalink) | |
Member: 44566 Status: Offline Thanks Meter: 7 | Thanks Quote:
I APPRECIATE BR FURIOUS PHEEKY | |
12-21-2004, 19:19 | #5 (permalink) | |
Member: 91102 Status: Offline Thanks Meter: 34 | Quote:
best of luck chowdary | |
All NEC USB Drivers Here ... Enjoy ;) | the_frightener | NEC | 249 | 12-01-2012 14:56 |
SEUS usb drivers interfering with Kulankendi usb drivers | tino.s | KULANKENDI Server | 2 | 05-17-2007 12:17 |
All NEC USB Drivers Here | hackers2gsm | NEC | 2 | 08-21-2006 00:29 |
nec usb driver | velimir79sl | NEC | 2 | 07-25-2006 21:53 |
need help with c350 usb drivers with pst | arism | Motorola P2k | 0 | 11-15-2004 11:13 |
