07-19-2005, 14:17 | #1 (permalink) |
Insane Poster Join Date: Jul 2004 Age: 48
Member: 75483 Status: Offline Thanks Meter: 13 | Problems downgrading NEC 338 v4 i tried to downgrade NEC 338 v4 with the new HACK3R2 downgrader and it went to 100%. when i switched the phone on, the phones stuck/freezes on the NEC screen. when i try to unlock it it still says V1.04. What shall i do? help. Hack3r2k??? Thanks in advance |
07-19-2005, 14:27 | #2 (permalink) |
Freak Poster Join Date: Dec 2004 Location: Inside Darkness Age: 39
Member: 101449 Status: Offline Sonork: 100.1585880 Thanks Meter: 10 | yeah very good question i need some information about this subject can mr hack tell me what i have to do for this model plz .............. best regards man |
07-19-2005, 19:27 | #3 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | Flash using soft. Phone without battery, drivers must be installed and u start falsher soft when phone becomes blue. You wait soft to finish flashing and you unlock after using NEC USB. Br |
07-20-2005, 11:11 | #4 (permalink) | |
Member: 75483 Status: Offline Thanks Meter: 13 | Quote:
do you hv to install the drivers that came with ur software or can you use the drivers that were previously given to us by furious tem for NEC 338? Thanks | |
07-21-2005, 22:03 | #7 (permalink) | |
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,570 | Quote:
Br | |
07-22-2005, 00:08 | #8 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48403 Status: Offline Thanks Meter: 1 | it starts to flash takes quite a while to get around to 60% then zooms to 100% and says flash is complete and colour of lcd changes. Then powered off phone and powered on tried unlocking but get imei error. |
07-22-2005, 00:16 | #9 (permalink) | |
No Life Poster Join Date: May 2003 Location: Jamaica
Member: 28559 Status: Offline Thanks Meter: 85 | Quote:
07-22-2005, 11:34 | #11 (permalink) |
Member: 75483 Status: Offline Thanks Meter: 13 | exactly the same thing happens to me, goes to around 50% and takes a lot of time and then quickly goes 100% and says successfull. the lcd on the phone turns green and says something like RAM OK and something else ok as well. when u power on the phone it freezes at the NEC screen and nothing happens and when u try and unlock it it still say v1.04 and give imei error. |
07-22-2005, 12:37 | #14 (permalink) | |
@ TENKIN, the phone will switch on just keep the button pressed for a while, if not then put it on charge and then try and switch it on. Thanks | |
NEC 338 v4 dead during downgrade - Can anyone help? | kiani187 | NEC | 1 | 10-29-2007 04:13 |
NEC 338 v4 dead during downgrade | kiani187 | FuriouS II | 1 | 08-24-2006 22:14 |
FIRST IN THE WORLD!!! - - - NEC 338 v4 DIRECT UNLOCK - - NO DOWNGRADE!! | irishclips | Main Sales Section | 0 | 05-25-2006 12:01 |
Great Problem With Downgrading Nec 338! Urgent Need Help! | KUBAT1 | NEC | 1 | 03-17-2006 10:41 |
nec 338 v4 downgrade | TEKIN | FuriouS II | 4 | 09-19-2005 10:27 |
