10-04-2004, 09:39 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Liverpool, UK Age: 40
Member: 75232 Status: Offline Thanks Meter: 12 | sharp tm100 problem program says sending boot and then error regards ina @ fonefix |
10-04-2004, 11:38 | #3 (permalink) |
Member: 75232 Status: Offline Thanks Meter: 12 | tm100 problem hi thanks for the quick reply. a screen shot is attached, i hope this helps regards ian @ fonefix Last edited by FoneFixUk; 01-30-2006 at 18:09. |
10-04-2004, 13:39 | #8 (permalink) |
No Life Poster Join Date: May 2004 Location: UK Age: 52
Member: 86956 Status: Offline Thanks Meter: 104 | yes serial cable on COM1 with 9v powering it...phone should be on with no sim...then press unlock...try restarting your computer...worked when i had problems! |
10-05-2004, 06:39 | #13 (permalink) |
No Life Poster Join Date: Jul 2004 Location: P A K I S T A N Age: 49
Member: 75644 Status: Offline Thanks Meter: 5 | try to use a original data cable hi br the serial cable which they ve provided didnt work so u should ve to make a another data by ur self. that could be work 100% u can try that. cause im suffering with the same problm. |
10-06-2004, 19:54 | #15 (permalink) | |
Freak Poster Join Date: Dec 2003 Location: heaven
Member: 46602 Status: Offline Sonork: 100.61437 Thanks Meter: 7 | hi Quote:
use the gx30 ordinary cable with u box (universal box ) working perfect ,before i was also having the same problem but now the problem is solved and unlock many pieces or t100 and gx30. bye.. | |
Sharp TM100 problem with manualy code entering!!!!!!!! | dedekwien | Sharp | 4 | 04-21-2005 13:40 |
Problems with Sharp TM100 | Raver85 | Sharp | 2 | 04-21-2005 11:38 |
who can unlock my sharp TM100 for me .. | jack32631 | Sharp | 13 | 07-25-2004 15:24 |
Data cable for Sharp GX30 & Sharp TM100 I need | boni | Wanted Products | 2 | 07-15-2004 10:21 |
NEED SHARP TM100 Pinouts | dominik | Sharp | 1 | 06-03-2004 20:58 |
