11-24-2004, 19:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: romania Age: 48
Member: 48215 Status: Offline Thanks Meter: 19 | Gx25 can be unlocked by furious like gx15 Regards |
The Following User Says Thank You to crysst For This Useful Post: |
12-02-2004, 21:45 | #7 (permalink) |
Member: 48215 Status: Offline Thanks Meter: 19 | easy Conect you gx25 like gx 15. select right com port and press unlock. to the screen will see xxxxxx then falow the instruction from the program: press 1 then................... |
12-02-2004, 22:57 | #9 (permalink) |
Member: 48215 Status: Offline Thanks Meter: 19 | if you got error to 3% then the conection is not good. First you must have instaled gx15 usb drivers Second you must use a usb cable for gx15 Third select right com port where usb emulate (for me was com 6) and the battery must be full. Regards |
12-02-2004, 23:19 | #10 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Europe
Member: 69725 Status: Offline Thanks Meter: 36 | Where to set or check this USB emulate I have instaled drivers... but how can I do all this by USB cable if we talk about furious which support only COM port connection? Is that emulate respoinsible for this? Sorry if I don't know something as you know but I am trying and no success thanks for your help anyway |
12-02-2004, 23:23 | #11 (permalink) |
Member: 48215 Status: Offline Thanks Meter: 19 | Sincerly, I dont know how see what port the driver emulated but you can try all the ports you have in program...... cannot be more.....take 1 and then 2 and......until the phone will be conected. |
12-02-2004, 23:25 | #13 (permalink) |
No Life Poster Join Date: Apr 2003 Location: United kingdom Age: 64
Member: 26440 Status: Offline Thanks Meter: 6 | 1. install gx 15 driver 2. connect the nec usb cable 2 the gx15 and all the driver should install. 3. when it says the hardware is correctly installed open under system, device mange and check which com-port is assigned 2 the gx15. 4. run the sharp gx15 unlocker and match the com-port from the drop down list. 5. follow instructions. |
12-02-2004, 23:29 | #15 (permalink) |
Member: 26440 Status: Offline Thanks Meter: 6 | 1. nstall only gx15 driver, connect the usb (nec cable which comes with furious) 2 the gx-15 and power on the fone.cant remember exactly but i think fone was on when i press unlock . |
lg u310 can be unlocked by furious gold | aleem26 | LG | 6 | 07-09-2011 15:20 |
lg u400 can be unlocked with furious?(Solved) | GSMman187 | FuriousGold | 5 | 10-21-2009 08:33 |
Sharp GX25 can be unlocked?? | zakiyyboss | FuriouS II | 1 | 11-06-2006 17:41 |
can anybody confirm if z105 can be unlock by choosing x430 in ust | ashvin | QUALCOMM Models (3G) | 2 | 08-06-2005 20:55 |
is this version can be unlocked with furious 3G free ?? | chavrotti | NEC | 21 | 01-03-2005 11:44 |
