01-07-2009, 15:10 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 45
Member: 348590 Status: Offline Sonork: 100.108198 Thanks Meter: 200 | Alcatel c701 from argentina problem... :::USE FLASH ON SUPPORT WORK 100%::: Flash ID.: 017E3022 , AMD 16 Mb. Firmware Ver. : 19N Phone Type : C701A-7ATLAR3 Operator/Country : MOVISTAR / ARGENTINA Language : BRA ENG SPA FRE ITA Phone IMEI : 011073-00-674716-0 Backup File Saved.. Phone Connected Ok.. Calculating.... NCK Code : 1835184026 SPCK Code : 1780765494 Insert Not supported Sim In The Phone Power ON Type You Code in Keyboard Press OK Key Calculated Codes...OK... Phone Disconnected ... |
01-07-2009, 16:09 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | use last polarbox version (current 204) if problem persist then simply flash it with polarbox and unbranded firmware, you will have phone unlocked and fully unbranded regards |
The Following User Says Thank You to thecult For This Useful Post: |
01-08-2009, 02:11 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | read code work freind, but in ur case: phone was flashed before (polar give correct code only from original eeprom/imei) OR ur phone have a new firmware solution: try flash methode (work 100%) br <= The_Gorr => |
again wrong code readed in alcatel :::USE FLASH ON SUPPORT WORK 100%::: | luinaranjo | PolarBox 3 | 3 | 01-22-2009 23:37 |
To Supporter Can We Have Original Flashes On Support ? | tsarkh | UST Pro II | 6 | 06-01-2008 21:08 |
31/05/2007 New VLE ALCATEL flashes on support ! | .:hack3r2k:. | FuriousGold | 11 | 11-10-2007 19:51 |
I need arabic flash file for KG245 as the flash on support did not work | tsarkh | VygisToolbox | 2 | 10-25-2007 23:14 |
