09-28-2009, 14:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Cuba Age: 45
Member: 1020744 Status: Offline Thanks Meter: 428 | Cable Problem??? :::ANSWERED::: Samsung M130L, I use the E210 cable, but when I connect it to the phone, the phone start, but the box says press power on. ....so, does not connect. note: this E210 have RJ45 only, no USB. any clue?? thanks |
09-28-2009, 14:50 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Dominican Republic
Member: 469532 Status: Offline Sonork: TG: CodebUnlocks Thanks Meter: 868 | Quote:
only need cut the white cable of ur rj45 cable is V++, whit this modification u get a c450 cable | |
09-28-2009, 21:50 | #4 (permalink) |
Freak Poster Join Date: Jun 2004 Location: CUBA Age: 45
Member: 69330 Status: Offline Thanks Meter: 125 | Check the Cable just check the cable using e210 pinout and ohmmeter to messure the continuity between both cable side. maybe u can solve ur problem like this. if the cable is ok just try other cable. BR CrossX |
09-29-2009, 13:20 | #5 (permalink) |
Member: 1020744 Status: Offline Thanks Meter: 428 | So... I'm a little missed with this... this model Use E210 or C450 cable?? I think the E210 is not the right for it, but I don't know if the C450 fix on it. BTW, polar box says "use E700" cable. |
09-29-2009, 13:33 | #6 (permalink) | |
yes is tru polar says "use E700" but u must use c450 cable if u don't have u need fix e210 cable cutting v++ cable. tested many times... | |
The Following User Says Thank You to Mr_F10ch3 For This Useful Post: |
09-29-2009, 13:57 | #7 (permalink) | |
Member: 1020744 Status: Offline Thanks Meter: 428 | Quote:
will be cool if the Team, Polar Box Team, fix this on the soft, cable description in samsung, or at least says wish cable for models to use. thanks people | |
vodafone 715 PROBLEM [ANSWERED] | juliog | PolarBox 3 | 16 | 08-24-2011 17:15 |
Missed Cables List. :::ANSWERED::: | BackSlash_cu | PolarBox 3 | 4 | 09-02-2009 14:06 |
List of cable please :::ANSWERED::: | PuHiG | PolarBox 3 | 2 | 07-09-2009 09:17 |
unlock s-218 with easy flash cable...possible? :::ANSWERED::: | husainm | PolarBox 3 | 2 | 04-07-2009 11:31 |
polar box cable problem.. :::ANSWERED::: | bhernz | PolarBox 3 | 3 | 03-15-2009 05:59 |
