06-04-2009, 19:36 | #2 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 1000097 Status: Offline Thanks Meter: 245 | if u are using original usb cable then download special driver from support are (must use last update 2.14) |
The Following 2 Users Say Thank You to .:Always here:. For This Useful Post: |
06-04-2009, 21:16 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | freind, just use last update 2.1.4 select ur model from list see in black window of polar instruction and make unlock that's all br <= The_Gorr => |
06-06-2009, 23:30 | #5 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Unlock world
Member: 242469 Status: Offline Thanks Meter: 503 | Quote: very easy friend with polar last version ........... read intruction black box ..... in 5 seconds you have UNLOCK CODE B.R | |
The Following User Says Thank You to octavyus For This Useful Post: |
06-08-2009, 16:42 | #6 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: KEF_TUNISIA
Member: 681313 Status: Offline Thanks Meter: 506 | Quote:
hope next update support all version s8300 | |
06-12-2009, 11:37 | #7 (permalink) |
No Life Poster Join Date: Apr 2002 Location: South Spain Age: 41
Member: 10905 Status: Offline Thanks Meter: 109 | I tried both Modes and none is working, any advice? Thanks Connecting ... Phone Model : GT-S8300 Phone Network : 214 07 Phone S/W : S830NBGIC Phone IMEI : 359043-02-357369-1 ERROR Phone Not Readed... |
06-12-2009, 11:40 | #8 (permalink) |
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | 1- use last update 2.1.6 2- use ReadPlock and check if phone code is enabled, if yes, desable it 3- check phone port number and change it under number 10 4- be sure that ur phone is not s8300v cause still not supported for the moment br <= The_Gorr => |
06-18-2009, 09:48 | #10 (permalink) | |
Freak Poster Join Date: Oct 2004 Location: Tunisia
Member: 88177 Status: Offline Sonork: 1594092 Thanks Meter: 71 | Quote:
hi biri, 1stly u must verify ur phone version ==> if Firmware versions higher than C4 can't be unlocked you must flash your phone with C4 or lower version. Since the only firmware for S8300v on support area is C6, you must flash it with S8300 firmware to unlock it. But you can't because the S8300v and S8300 have different boot files. So u must you must download S8300 downloader and flash the boot files of your phone with S8300 boot files. After this you can flash your phone with S8300 files and unlock it its like U700v procedure. good luck Last edited by The_Gorr; 06-18-2009 at 11:54. | |
how to unlock samsung s8300 ??? | who_i | Z3X-Team Products | 8 | 09-19-2011 14:24 |
fail to unlock samsung A707. [ANSWERED] | luinaranjo | PolarBox 3 | 15 | 10-13-2009 15:45 |
hot to unlock samsung t739 [ANSWERED] | ALGUIEN | PolarBox 3 | 1 | 09-01-2009 23:46 |
How to Unlock samsung F480V :::ANSWERED::: | julio05 | PolarBox 3 | 1 | 07-07-2009 23:26 |
How to unlock Samsung S8300 with Z3X-team | hoangtruongson | Z3X-Team Products | 2 | 05-27-2009 07:25 |
