05-20-2013, 17:47 | #1 (permalink) |
Junior Member Join Date: Jan 2012
Member: 1714573 Status: Offline Thanks Meter: 2 | i9100 [ANSWERED] trying to unlock samsung i9100 with Polar 3.23 It says: Uploading data to SCARD then it reboots phone to recovery mode but there is no GB_UPDATE I tried 5 or 6 times, checked the card, etc. but it doesn't write the file. any ideas? or can u link the file so i can write it manually to SD card? cheers |
05-21-2013, 10:29 | #3 (permalink) |
Member: 1714573 Status: Offline Thanks Meter: 2 | Yes, tried another card. I never seen the software try to write to SDcard before for i9100, I assume it was new with v3.23. I just tried it again but no good. Anyone link me the .ZIP for this phone? So I can write it to the SD card myself thanks |
05-21-2013, 16:04 | #4 (permalink) |
Member: 1714573 Status: Offline Thanks Meter: 2 | okay, I downloaded v3.24 but get the same result Customer keeps ringing me so I have had to order code from IMEI server. However, maybe it needs looking into? Thanks anyway guys |
05-23-2013, 13:54 | #5 (permalink) |
Freak Poster Join Date: Jan 2011 Location: norfolk Age: 54
Member: 1486828 Status: Offline Sonork: pcs1234 Thanks Meter: 53 | same here .the phone is on 4.1.2. it did the same thing for me said it was uploading to micro sd,but didnt .the micro sd is fine and tested.please sort asap...many thanks |
08-07-2013, 18:56 | #8 (permalink) |
Member: 1714573 Status: Offline Thanks Meter: 2 | Solution! OK, think I know the problem. 4.1.2 reads phone memory as a memory card. When Polar writes to SD card it actually writes it to phone memory. So, go to options / File Manager and copy the "GBupdate.zip" from "sdcard0" to "extSdcard". The file is now there when in recovery mode you select "apply update from ext storage". I also find it easier to select "SuperUser" app, go to options and permisions. select Always allow. That way Polar can access what it needs without you having to click "allow" on phone screen. You can reverse this later. -------------------------------- Device Found... Checking if Root... Root TRUE... Checking Hash Type...Please Wait... Phone Connected Ok... Reading SpLock ... Contacting With Server...Wait... Consumed 0 , Credits left: 30 Phone Codes... ___________________ Net Code : 12345678 Sub Code : 00000000 SP Code : 00000000 SIM Code : 00000000 UnFreeze Code : 12345678 Insert Not supported Sim In The Phone After type You Code in Keyboard Press Calling OK Key Maybe get the message < Unlock Error > But you Device Is Unlocked Codes Readed Ok... Rebooting Phone... ----------------------------------- Hope this helps people having this problem |
The Following User Says Thank You to compulandia For This Useful Post: |
08-08-2013, 03:10 | #9 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: Inside PolarBox
Member: 10286 Status: Offline Sonork: 100.90962 Thanks Meter: 4,353 | Quote:
Thnks for your info, we will take a look ... | |
