10-09-2009, 15:15 | #2 (permalink) |
No Life Poster Join Date: Oct 2008 Location: WHERE THE WORLD ENDS
Member: 885625 Status: Offline Sonork: 100.1589108 Thanks Meter: 2,432 | Hi friend use ver 2.2.8 you are using an old version ,download and install samsung drivers from polar box2 support,all will be fine,post result,suunnyy |
10-09-2009, 20:11 | #6 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Tarragona, Spain
Member: 36126 Status: Offline Thanks Meter: 311 | Hello Friend, This Phone J700 has nothing to do with Server , POLAR BOX's POWER is suficcient for this phone just use a good cable only RJ45 conexion is needed no need the USB conexion and you will see the results that how fast polar unlock this mobile. TIP: if u are trying to do a new J700_i T somthing like that just select E250i from the list and do direct unlock within 3 seconds mobile will unlock. WBR Wasim |
10-11-2009, 14:57 | #8 (permalink) |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 48
Member: 185608 Status: Offline Thanks Meter: 592 | Samsung phones! Cheick your cable or hardware,i say hardware mean that clean the main board and charge jack.To finish you must know that problem is not your box.POLAR BOX2 very powerfull on SAMSUNG PHONES!So try in that way i advice!Will work! |
u800 unlock problem :::SOLVED::: | crazytel | PolarBox 3 | 6 | 08-18-2009 08:13 |
NEC 342i unlock problem :::SOLVED::: | dml | PolarBox 3 | 8 | 06-11-2009 08:10 |
vodafone 810 unlock problem :::SOLVED::: | djhobart | PolarBox 3 | 4 | 04-15-2009 13:27 |
ku990 server problem :::SOLVED::: | japunlock | PolarBox 3 | 3 | 01-09-2009 00:44 |
Samsung J700 Connection Problems | Sammyjane | Samsung Hardware Repair | 0 | 04-21-2008 10:42 |
